12cm housing on gen 1
Old Mar 30, 2003 | 03:57 PM
nevrenufhp's Avatar
Just wondering if it would work to put on my old 12cm W/gated housing on a '93. I was thinking of doing it to a buddy's truck and add a little more fuel at the same time. Trying to think of a good use for the old stock stuff.
Old Mar 30, 2003 | 04:49 PM
atc250r's Avatar
Re:12cm housing on gen 1
I am pretty sure it will, just plumb a line from the intake manifold to the wastegate so it will be able to do its job. I would also guess the exhaust may have to be moved back slightly since the wastegated housing is a bit longer.<br><br>John<br><br>
Old Mar 30, 2003 | 09:38 PM
nevrenufhp's Avatar
So, is it gonna be a good thing? I can see the lag reduction and better boost #'s...that means I HAVE to turn up the pump ;D! Worth a shot since I'm not going to use it anymore. His truck is all bone stock too, he'll like the new found ponies!
Old Mar 30, 2003 | 10:02 PM
Monty's Avatar
The 12 will give a noticeable difference in spoolup. However, if you plan on towing or going to extremes with mods in the future, the 12 will have to come off and replaced by a 14 or a 16 housing to reduce EGT's
Old Mar 30, 2003 | 10:17 PM
dodgeman01's Avatar
I guess you are talking about just switching the housing. I thought they would not interchange because they are different turbos? If they can interchange then tomarrow my 18 will hit the can and in its place will be my 12.<br><br>DM01
Old Mar 31, 2003 | 08:01 AM
nevrenufhp's Avatar
I thought it would work because the same part # for 16 housings fit both gen 1 &amp; 2.
Old Mar 31, 2003 | 05:43 PM
Monty's Avatar
A 12 will work. The only change needed is shortening of the downpipe. As I recall I believe it is about 1 1/2&quot;.
Old Mar 31, 2003 | 06:42 PM
nevrenufhp's Avatar
If not the pipe will hit the fire wall? That would put a damper on things :'(. Like the opposite of swapping in my 16 from a 12.
ajbirken
Sep 6, 2006 12:11 AM
Denis
Mar 2, 2004 06:52 AM
HOHN
Dec 7, 2003 02:07 PM
cethane
Oct 29, 2003 09:58 PM
cethane
Dec 16, 2002 11:07 AM
