Where do I get a 12cm housing and how much$?
Old Feb 28, 2004 | 08:31 AM
Denis's Avatar
Subject line says it all!
Thanks,
Denis
Old Feb 28, 2004 | 09:44 AM
Jim Shulmister's Avatar
Muted User
Dont buy the housing by itself. You can get a hx-35 with the 12 together for about the same price as just the housing. ($300 range)
-Jim-
Old Feb 28, 2004 | 09:48 AM
Denis's Avatar
Okay, thanks, Jim!
Old Feb 28, 2004 | 04:22 PM
I've never seen a 12 cm housing priced that high. They go for $50 or so on Ebay, they also show up in the classifieds on DTR. Try placing a wanted ad in the classifieds. I got mine for killin' a KDP, to most guys who've taken them off they're just another piece of junk cluttering the garage.
Old Feb 29, 2004 | 06:55 AM
Denis's Avatar
Cool, thanks, Dave.
Old Feb 29, 2004 | 09:40 PM
darloa's Avatar
Hey Denis, I may have one that I'm willing to sell, if your interested and your not in a big hurry. PM me for details. Will be going to a 16 before long to help with EGT's. Darl
Old Mar 1, 2004 | 01:24 PM
furious70's Avatar
Does a stock downpipe have length to make the 12 work, or do you need more/different pipe?
Old Mar 1, 2004 | 03:27 PM
Furious70-
You actually need less pipe. The 12 cm housing is about 1.5 inches longer due to the wastegate. Some guys have had success pushing the downpipe back, others have cut a section out and rewelded. I upgraded my exhaust at the same time I did the turbo swap. The downpipe that came with the system had the flange welded into the pipe, so I cut the pipe off square as far back as I could, then machined the weld off the flange, stuck the flange back in the pipe and had a buddy tig it up. The heat shield clears the heater box soundproofing by a gnats whisker. With your 5 speed you're almost guaranteed get flutter at the bottom of 4th and 5th out of this swap. Doesn't seem to affect the performance any, but some say it's bad for the turbo.
Old Mar 2, 2004 | 06:52 AM
Denis's Avatar
Hi Darl, thanks for the post. I think I've found one, but it might be a few days to work it out. I'll let you know.
Thanks!
Denis
Magnum Salvage
Jul 24, 2008 04:58 AM
Micaiahfied
Feb 8, 2007 05:34 PM
ajbirken
Sep 6, 2006 12:11 AM
gman07
Apr 10, 2006 08:24 PM
HOHN
Dec 7, 2003 02:07 PM
