1000 Ft lbs, what's it take (24v)?????
Old Mar 7, 2005 | 11:43 AM
SjLingenfelter's Avatar
Did they mention a BIG pocket!
Old Mar 7, 2005 | 12:50 PM
RowJ's Avatar
Like Jet Pilot said above...a full B-1 would be your best bet but won't work with you e-brake, I don't think. Your going to have to go with the hybrid as far as I know. Nothing wrong with the Drag Comp but it will get toasty very quickly and you will need to turn it way down for towing. Just so your aware. If your looking for 1,000 lb-ft towing torque, IMO, it will take twins.
RJ
Old Mar 7, 2005 | 01:09 PM
rharveysr's Avatar
Your EGT's will be out of sight with the Drag Comp, DD3's & HX40/35 Hybrid!
My 12v is running some nice EDMs and yet with my PDR HX35/14 I could(if I wanted) push it to 1400*+. But towing this turbo moved enough air at 1800 rpms that my egts were actually cooler than with the stock 215s.
It all depends on where you want your power..if you want to keep things cool in the lower range of rpms..you will need to tighten the housing up a little or you will run warm. Now if all you are looking for is the top end...and more air..go with a bigger housing or full B-1
As far as needing twins to make 1000lbs or torque...you dont! Now if you want to be able to use that 1000lbs of torque for towing...then yes you will...
All depends on what you want your truck to do..
Rick
Old Mar 7, 2005 | 01:15 PM
mcoleman's Avatar
I tow every weekend with my combination but I leave the comp on 3X3 and I'm only dragging 8000-9000 pounds around at altitudes in the 1700 feet and under range. On 5X5 where the actual drag portion comes in to play by not de-fueling over 2700rpm you would be fogging out everything within a mile of the back of the truck. My horsetrailer is white but it wouldn't be for long if I tried to tow on that setting. And yes it gets hot quick on 5X5. That's why it's called a Drag version. Short term usuage only.
Old Mar 7, 2005 | 01:49 PM
CTD_Neil's Avatar
Alot of good info so far! I don't tow much at all, just want to hit the magic 1000 number. I wouldn't mind having to turn it way down to tow. Who makes the B1 turbo?? What hybrids are available that will allow me to keep my ex-brake??
Old Mar 7, 2005 | 05:48 PM
CTD_Neil's Avatar
Old Mar 7, 2005 | 10:45 PM
CTD_Neil's Avatar
With all the talk of different turbos, can someone post who makes which turbos? and where to get them? Thanks
Old Mar 7, 2005 | 11:22 PM
mkubacak's Avatar
Piers has two turbos that will allow you to keep your Banks Brake. I called a couple of months ago and asked the same question. I do not want to invest in a new exhaust brake unless i decide to go to twins. But, then I would need a major cash infusion. The Piers turbos are:
The PDR HX35 - http://www.piersdiesel.com/Hx35.htm
and the B-1-EX3 - http://www.piersdiesel.com/B1b.htm
I am pretty sure the Dodgezilla will work also as it has the HX-35 outlet.
http://www.protintnw.com/dodgezilla_turbo.htm
There may be others, and if there are, someone will surely chime in and let you know.
Old Mar 8, 2005 | 07:38 AM
mooseman's Avatar
Try www.htturbo.com
Old Mar 8, 2005 | 02:04 PM
CTD_Neil's Avatar
Thanks Moose!
Old Mar 8, 2005 | 04:28 PM
Beast2B's Avatar
I just dyno'd 434hp/975tq last weekend with my mods. Comp 5x5 with the air filter off. Near 1350*. I got back from Baja the weekend before that towing 12k trailer, probably 20k gcw. This combo is very driveable. From what I've read, the B1 series of turbos are NEARLY indestructable and I can turn the Comp off/on as needed. From my experience with this stuff, I'd go with a regular B1 turbo (exe3 is nice for downpipe and brake, but you neck it right back down to 3.5" instead of exe4 for HX40 4" v-clamp outlet or normal B1 outlet), EDM 3.5 or 4.
Old Mar 8, 2005 | 05:23 PM
CTD_Neil's Avatar
Thanks Beast, What HP are your injectors? I'll look into the B1 series turbos. Hey are you going to Imlers next Dyno-Day?? I'm going to run just to see where I am now.
Old Mar 11, 2005 | 11:56 AM
CTD_Neil's Avatar
btt
king5335
26
Jan 17, 2010 07:57 PM
buddy26
16
Jan 14, 2009 07:29 PM
Termite 06
Jun 4, 2006 12:40 AM
JImbo1
Aug 27, 2003 08:13 AM
1ST GEN.
Oct 31, 2002 09:06 PM
