XM radio constantly loading?
Old Oct 14, 2007 | 12:34 PM
Txwelder's Avatar
When I get in the truck first thing, the XM will work on the station it is on but as soon as I change the station, it goes to a "LOADING" mode and will stay that way for up to 1/2 hour or so before it comes back on. Anybody else have this problem? Also it seems like every time I go under something as thin as a power line it drops reception, what gives? It is a roadie II. Thanks.
Old Oct 14, 2007 | 12:45 PM
BigHornCTD's Avatar
I wonder if your antenna is going bad, or the wiring is chaffed somewhere and is grounding itself somewhere.
Old Oct 14, 2007 | 01:29 PM
tn hillbilly's Avatar
I had that same issue, called customer support and they fixed it.
Marshall
Old Oct 14, 2007 | 04:01 PM
electrifried's Avatar
I have had that happen with a bad antenna wire.
One of my Skyfi units does that once in a while and usually unplugging it for a minuit resets it.
Good luck
Old Oct 16, 2007 | 05:27 AM
Txwelder's Avatar
Ill give them a call and see what comes of it. Thanks.
Old Oct 16, 2007 | 10:56 AM
Diesel_Storm's Avatar
i would call them. it sounds like the satellite is having trouble locating your XM receiver. there is something they can do to fix that.
similar to pinging a computer to see if it is on a network.
Old Oct 16, 2007 | 11:00 AM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Yep, me too every now and then. When it does happen I turn the power off and back on, which seems to fix it.
Old Oct 16, 2007 | 02:46 PM
DmaxEter's Avatar
Mine has been doing it every morning for about two weeks now. When I get in the truck my music will play for about 1 minute and then go to searching for signal saying "antenna". After about 5 miles its just fine. I think They got a problem!
Old Oct 17, 2007 | 07:50 PM
diesel_burner's Avatar
Mine is the same way. I ussally shut the truck down on the street then fire up well still rolling and "90% of the time it works 60% of the time". Little anchorman for you guys.
Old Oct 17, 2007 | 09:21 PM
GasganoFJ60's Avatar
Sounds like a bad antenna wire to me.
I ran mine through my door jam and the old door pinched it at the hinge. Frayed the wire to a sliver.
Sad thing is though, an antenna costs about as much as a new deck so look at this as a chance to upgrade. Thats what I did.
New antennas at Best Buy were about $40....a new unit was $50.
UPGRADE
And as far as losing signal when parked under something, it doesn't surprise me. If you put your hand over the antenna puck itll cut off. If Im parked under the tree in my front yard just right ill have a weak signal.
HL649
Mar 27, 2012 08:19 PM
Arlon
Dec 29, 2005 09:21 AM
RED99CTD
17
Dec 7, 2005 09:59 AM
Lil Dog
Jan 17, 2005 05:34 PM
04ctd
Nov 26, 2004 01:08 PM
