wheel swap
Old Oct 1, 2003 | 12:12 PM
dieselcrazy's Avatar
wheel swap
to make factory alloys from a 2001 fit on a 97 all i have to do is remove some material from the outside edge of the rear drums till they fit inside the wheel......is this correct ???
Old Oct 2, 2003 | 07:55 AM
Re:wheel swap
no one knows ???
Old Oct 2, 2003 | 08:00 AM
erics76's Avatar
Re:wheel swap
I've heard the same thing, but I couldn't tell ya for sure.
Old Oct 2, 2003 | 05:58 PM
Re:wheel swap
bringing it back to the top help please
Old Oct 3, 2003 | 12:15 PM
Redleg's Avatar
Re:wheel swap
try it in 2nd gen, not all those guys come down here to hang much.
Old Oct 3, 2003 | 08:13 PM
phox_mulder's Avatar
Re:wheel swap
I'd say try it before you do anything.
Find someone with original wheels and see if they'll let you try one on for size.
I have a set of OEM's sitting on the side of the garage, and wouldn't mind at all letting someone try them on for size.
Gotta be a nice newer Dodge owner around you somewhere's.
phox
Old Oct 5, 2003 | 09:58 AM
berner's Avatar
Re:wheel swap
I remember reading somewhere (?) that someone made spacers out of 1/4" steel. Might not be worth it as you'd have to balance the spacers and get them machined so that they'd fit exactly centered on the drum.
Old Oct 6, 2003 | 10:27 AM
Re:wheel swap
i checked at a big truck shop that does brake work and they werent sure it should be done.. something about the drums needing to be balanced ???
Old Oct 6, 2003 | 10:48 AM
dodgeman01's Avatar
Re:wheel swap
Well I have heard if you put them on a break leathe*sp and have them turned down they will fit and be balanced.
DM01
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
Vic20
Apr 21, 2005 09:06 PM
03CumminZ4X4
Mar 31, 2004 04:32 PM
Carcrazyscott
Feb 10, 2004 08:46 PM
