Router Questions
Old Sep 19, 2004 | 12:06 AM
jrs_dodge_diesel's Avatar
Question Router Questions
Howdy y'all, just got my cable modem hooked up, WOW night and day from my old dial up. Any way I am computer savvy (I built the machine I am using now). Before I started using my cable modem I went and bought a router. It is a small Linksys router with a 4 port switch made by Cisco Systems. Brand new. I want one to have a good hardware firewall to protect my computer. Does anyone know how to control the ports. Like port 80 is the main port for the internet. I know there are may others. I need to know how to open and close the ports. That way I know there isn't a "back door" open to my computer. Any information would be appreciated.
Old Sep 19, 2004 | 12:30 AM
dieselminded's Avatar
Im @ a whoppin 28.8
k that is not m
congrats ,may I recommend
www.shareaza.com
Get the most out of your hard work
For you port question get a small program called CurrPorts youll find it at
http://freewarearena.org/PHPNuke/mod...wnload&cid=135
its help you manage your ports.
ENJOY
Old Sep 19, 2004 | 12:41 AM
upersleder's Avatar
i have one, you need to punch in the number it gives you in the book on your web browser. i forget what it is, but its like 192.1.1 something, then you can get into the spots where you can open/close your ports. i also called their tech line, they were very helpful.
Old Sep 19, 2004 | 12:58 AM
That IP is 192.168.1.1
Old Sep 19, 2004 | 01:23 AM
upersleder, I tried that idea you had. It does go into the router configuration. It does not have what I am looking for, I was hopin it would show me what is open / closed as far as ports. I downloaded the Currports program that dieselminded suggested. It works. Now I have to learn what ports are for what.
Old Sep 19, 2004 | 07:32 AM
jfpointer's Avatar
Some are well-known and established, such as 80 for http, 21 for ftp, etc. Here's a pretty good list: http://www.iana.org/assignments/port-numbers Nowadays, most home routers come with most of those ports turned off or disallowed by default, but it certainly can't hurt to check.
Old Sep 19, 2004 | 07:45 AM
Redleg's Avatar
Mines a Bosch 2 1/4 hp with both bases, single speed.
Old Sep 19, 2004 | 08:26 AM
jfpointer's Avatar
My "other" router is an old mustard yellow B&D.
Old Sep 19, 2004 | 11:34 AM
nickleinonen's Avatar
mine is a porter cable 1¾ hp [iirc?] single speed...
Old Sep 20, 2004 | 04:53 PM
upersleder's Avatar
jrs, glad you got it working anyways, after mine worked i just left it alone
BTW my other router is a porter cable with both bases!
Old Sep 20, 2004 | 05:21 PM
TPilaske's Avatar
Nozzleman
Feb 26, 2008 10:07 PM
crobtex
Jun 7, 2007 09:40 AM
jj3500
Mar 10, 2007 04:39 PM
hotdram
Apr 18, 2006 04:04 PM
12valve@heart
Nov 17, 2005 11:26 PM
