Wireless Router Problem
Old May 25, 2007 | 09:31 AM
crobtex's Avatar
Before my garage PC crashed, I was connecting using a Linksys wireless router and a D-Link USB wireless adapter.
I have replaced the HD, reloaded MS Home Edition SP2. Now, it shows my wireless network is available, but it keeps searching for the network address and will not connect. Any ideas..........?
Old May 25, 2007 | 09:58 AM
crobtex's Avatar
EDIT: That's "network address".
Old May 25, 2007 | 10:02 AM
Truckman0097's Avatar
Is there any Security on the router? can you plug into it and get to the internet? WEP key? try pluggin in with Ethernet cable and going into the routers configuration...
Old May 25, 2007 | 10:16 AM
crobtex's Avatar
I was hoping to get around doing this. The PC is in the garage and I don't have enough ethernet cable to reach that far. It may be my only alternative.
Old May 25, 2007 | 10:24 AM
Well, If you have a computer in the house, you can use it to go to the router config - or just take the router out to the garage and plug in out there. Is there security enabled on the router - if so, it may have an issue with the new software on the computer in the garage, The computer may no longer be set up to access the router.... also, have you tried the simple things like unplugging the router to let it reset itself? Unplug your modem, then unplug router.. and shut down computer... leave off for a couple minutes, then plug back in modem first and let it boot up, then plug in router and let it boot up, then turn on computer.... Sometimes you need to reboot them in the order which the signal comes in - ie. modem, router, computer...
Old May 25, 2007 | 10:26 AM
winkle's Avatar
Is the computer in the garage the one with the wireless adapter and router is connected to another computer?
Old May 25, 2007 | 10:32 AM
crobtex's Avatar
I have unplugged the cable modem and router several times, but try it again.
winkle, the router is connected to the cable modem in the house. The house PC has a PCI card and the garage pc has the usb adapter.
Old May 25, 2007 | 10:49 AM
AggieJustin's Avatar
I suppose you have a valid WEP key since it's letting you get to the point of trying to connect. Do you have a MAC filter on your network? I wouldn't expect this to be an issue since you're using the same wireless card as before, but it's something to check.
Don't count on much help from Linksys...their tech support line is horrible. I spent a few hours with them the other night and was no further than when I started.
Old May 25, 2007 | 10:54 AM
winkle's Avatar
I don't know if Linksys works the same as D-link router but on the D-link you can type in the IP address on the internet (ie..http//000.000.0.0)and bring up all your information and even make change to like security and so forth.
Old May 25, 2007 | 11:01 AM
crobtex's Avatar
I don't even think about calling Linksys.....been there before.
Old May 25, 2007 | 11:03 AM
crobtex's Avatar
I had forgot about that. Now all I have to do is remember has to get the IP address.
Old May 25, 2007 | 11:20 AM
winkle's Avatar
Go on the computer with the router attached to it go to the control panel click on network connection, double click on the connection and in the lower left hand corner you'll see a box that say details, that where it will list your IP address.
Old May 25, 2007 | 11:32 AM
crobtex's Avatar
Found it!
Last day of school, and I have have to go play Papaw for awhile and entertain the kids. I'll get back to this later.
Thanks,
Old May 25, 2007 | 05:05 PM
ropnjessi's Avatar
Make sure your SSID is set to "Broadcast".
Old Jun 6, 2007 | 08:48 PM
crobtex's Avatar
Sorry I took so long, but I finally got it up today. I ended up going with a Linksys USB. After reloading XP SP2, fixing some missing driver problems and over an hour with Linksys support, it's finally running.
