Leaky Injector on '97 Sunfire
Old Nov 25, 2007 | 10:23 AM
berner's Avatar
#4 injector on the wife's Sunfire is leaking. I don't feel like changing them all as we're thinking of selling the car. Can a guy just buy one injector? Am I going to be embarrassed asking for one?
Old Nov 25, 2007 | 11:18 AM
Yes, you can buy just one. The whole rail and injector assembly comes off as a unit, so you might as well replace them all. They've all been down the same road. If it's a V-6 you could just do the one bank where the leaker is.
Old Nov 25, 2007 | 11:55 AM
matego's Avatar
madhat's monkey boy...
Is it the injector or the o-ring leaking? They make o-ring kits, and if you look on e-bay I bet you could find a whole set of injectors for less than 10 bucks. There is a lot of people who hop up the 2.2l, which I assume you have, and replace the stockers for bigger ones.
Old Nov 25, 2007 | 12:01 PM
berner's Avatar
I haven't looked at it closely. The wiring terminal on top is wet with gas. And it is the 2.2L 4-banger.
Old Nov 25, 2007 | 12:32 PM
matego's Avatar
I looked at Advance, those little things are expensive. New about 67$, but there is a couple of them on ebay for 20 give or take. It looks like the s-10 injectors are the same, which may help. At the dealer I worked t out of school we always replaced the bad injector, not the whole bunch. Yeah, injectors can flow different rates. I personaly send my injectors to www.kgparts.com and he checks the flow and adjusts it for 6$ an injector. It may not hurt to pull all 4 and send to him. They disassemble them and rebuild them for a reasonable price. It might just need a o-ring in the body replaced or something. If it is no good, he does not charge for checking it out.
Old Nov 25, 2007 | 12:38 PM
torquefan's Avatar
Good advice above. I have replaced many single injectors in the past. Price varies a lot, from $50 to over $150 per injector. I have sent many in for cleaning and balance testing which works well even where you have one injector that's bad enough to cause a miss. In my experience though, they can't fix an injector that's leaking externally. I would buy one new one, and consider sending the rest in for cleaning.
Old Nov 25, 2007 | 12:45 PM
matego's Avatar
I never had one leaking externaly, so that is some good info to know. I have sent in new injectors for my 2.0 Cobalt and one of them was 11% higher flow than the rest. They were even Lucas high dollar injectors. It is worth the 24$ for peace of mind. Imagine if one was 11% less than the bunch.... fried piston! Three rich cylinders trying to compensate for the one lean, not good
Old Nov 25, 2007 | 03:13 PM
Before you decide to do just one, pop the plug off the top of the other three injectors. I had a Cherokee with one (I thought) leaking in that area, when I removed the plugs I found 3 more for a total of 4 out of 6 leaking at the connector. I replaced all 6.
Check RockAuto.com for prices, they are often pretty good compared to the local stores.
RussianVolk
Jun 29, 2010 01:13 AM
hotmopr
Jun 29, 2006 10:22 PM
Copenhagenjunkie
Aug 16, 2004 12:37 PM
country
Oct 1, 2003 03:54 AM
