leaky injector
Old Sep 30, 2003 | 08:38 PM
country's Avatar
leaky injector
one of my injectors is leaking up through the lock nut, this afternoon i pulled it out to see if there was any trash in between the head and the washer , just installed these injectors a couple of weeks ago, well cleaned the washer and bore , reinstalled the injector , noticed that it didn't fit good and snug , would move around in the injectotor bore queit a bit, i noticed this also before i pulled the injector out , when loosen the nut i just pulled it right out, well to make a long story short this thing is still leaking! why would that injector be so lose in the head? i know thats why it is leaking. gonna call bully dog tomorrow. any suggestions in the meantime?
Old Oct 1, 2003 | 12:35 AM
Bushy's Avatar
Patron Saint of 1st gens
Re:leaky injector
One thing I've learned to do... the hard way... is to make sure that each time you pull out or change injectors, make sure that each one has it's old washer on it... otherwise you'll end up "double washering". If you do that you'll need to pull them all out to find the culprit... it's always the last one of course...
There should be an "indexing ball" on the injector. That must fit into the slot at the bottom/outside of the injector bore. It should slip in fairly easy.
Check that stuff out and let us know if you have any other problems..
bob.
Old Oct 1, 2003 | 03:54 AM
country's Avatar
Re:leaky injector
yea check for all thhe washers , and the ball , injector just doesn't fit in the head good and snug ,and its just that one injector.
RussianVolk
Jun 29, 2010 01:13 AM
hotmopr
Jun 29, 2006 10:22 PM
viper
Jan 5, 2006 07:31 AM
G1625S
Sep 15, 2005 10:33 AM
