Lawn Mower Oil
Old Apr 6, 2008 | 08:40 PM
RSOPNCO1's Avatar
Question Lawn Mower Oil
What is the difference between 30 sae and 10-30 and is 10-30 ok to use in lawnmower. Figured it would be b/c it has a 30 on it. $7 a gallon vs $6/qt.
Old Apr 6, 2008 | 08:52 PM
wurkenman's Avatar
10-30 will probably foam to beat all get out. Use the 30 . These little motors get some hard use. Personally I only use Amsoil, but then again we are way out of the 6 bucks a gallon mark there.
Old Apr 6, 2008 | 10:25 PM
Guardrail's Avatar
I use 10W-30 in all my small motors. I've never had a problem and it does not foam a bit.
Old Apr 6, 2008 | 10:31 PM
DiEseLjunKy's Avatar
Ok I'm one of the brainwashed amsoil users around here too but in a lawn mower? I've always just used straight 30w whatever in my mower.
Old Apr 7, 2008 | 02:38 AM
Jeff in TD's Avatar
I'd just use whatever the maker of the mower calls for.
Some call for 30 weight and some call for 10W-30...
Old Apr 7, 2008 | 05:48 AM
jughead's Avatar
i use 15-40 diesel oil in all of my toys. no problems in 12-15 yrs.
Old Apr 7, 2008 | 07:13 AM
MikeyB's Avatar
I use 15w-40 Rotella in all my yard equipment and ATVs. My Honda lawn mower is 19 years old and still going strong.
MikeyB
Old Apr 7, 2008 | 08:37 AM
hertz's Avatar
If it calls for 30w use it there isn't as much detergents in 30w as 10-30w. 30w helps keep the lifters pumped up
Old Apr 7, 2008 | 09:06 AM
surfram's Avatar
Last season, I switched to Briggs & Stratton synthetic 5W-30 for my lawn tractor. Compared to generic SAE 30 lawn tractor oil, this stuff stayed extremely clean all season. I will use the synthetic Briggs & Stratton oil again this year.
http://www.briggsandstratton.com/mai...spx?pid=100074
Old Apr 7, 2008 | 10:15 AM
HOHN's Avatar
The reason a straight 30W is spec'd instead of a multi grade is that a small engine warms up so fast that there almost no such thing as a "cold start". You don't need the multigrade's superior viscosity index.
So, you use a straight 30w because you get more shear stability since there's a LOT of shearing in a small engine and they tend not to get the regular attention they need as far as oil changes.
I've switched to a 15w-40 in all my mowers and such and I like it.
I even tried a 0w-20 M1 once just to see how it went. The mower survived just fine, and started super easy. It vibrated more, though.
Old Apr 7, 2008 | 10:49 AM
hertz's Avatar
almost all new lawn mowers use 10-30w
Old Apr 7, 2008 | 01:16 PM
TexasCTD's Avatar
MikeyB
FWIW...I always run Castrol 30w in all my lawn mowers, generator etc. Just changed them all this past weekend........for this season.
But on Motorcycles and ATVS I thought you were supposed to run special oil designed for them by the manufacturers that also protected the transmission etc.
Old Apr 7, 2008 | 03:02 PM
MikeyB's Avatar
Motorcycle oils are really a gimmick. Nothing more than a HD oil like we use in diesels. Only thing to watch out for is oils containing moly when used with wet clutches.
We have a 1982 and a 1985 Honda Big Red that's still going strong. Nothing but Rotella in the sump. Also using Rotella in my 1998 Kawasaki Prairie 300 4x4.
MikeyB
Old Apr 7, 2008 | 05:35 PM
Good post from Hohn.
Bottom line, use what the engine maker calls for or take your chances.
Old Apr 7, 2008 | 09:04 PM
Rednax's Avatar
Briggs, for one, now recommends synthetic 5W-30 for their motors. This has been my choice for about 10 years on small engines. I have a $99 special with a Tecumseh that just keeps running like new on a lawnmower that sees a lot of abuse (dirt, rocks, etc). I'm finally dumping it for a re-engined commercial Snapper, it'll be a good second or trim mower for someone.
Oil almost never blackens when you use a quality brand, synthetic formula, in the right weight/viscosity, IMO.
More important: Clean air filters.
