Jetta TDI
Old Mar 22, 2007 | 12:45 PM
  #76
Diesel-Dan's Avatar
ALRIGHT BUCK......do some asking around for me:
Figured out my issue:
Injection PUmp timing slipped. It was off by 1 tooth from what i was told. Can the pump gear slip on the pump shaft like the 12 6BT's? OR can it jump a tooth on the belt......im not really buying this one...it runs too good and i woudl feel that it would jump at the cam or crank before the pump.....
We advanced the timing just a touch and now fires up and runs like a champ........and now my wife wants to drive it again............
Old Mar 22, 2007 | 01:22 PM
  #77
Buckshotmckee's Avatar
How many miles on this guy again??? If it jumped timing then its more then likely got a bad tensioner. Do you know if anyone has ever messed with the timing on it prior to your purchase??? If so, it's possible they didn't replace the 3 bolts on the pump if they loosened them, there a stretch bolt.
Old Mar 22, 2007 | 01:27 PM
  #78
Diesel-Dan's Avatar
WE bought as is at 80,000. From what we know, its never been touched. I know when we do it next week, we are going to use non-streach bolts for the IP. We figured that if it did jump, the tentioner would be weak....and the pump much be on the "slack" side of the T-Belt.....so...i dont know......just seems odd that it would jump a Tooth over slipping the shaft or pump rotating.....
Old Mar 22, 2007 | 01:32 PM
  #79
Well in that case, 80k, that sucker is past due for a timing belt! No wonder why it jumped. Replace the timing belt, tensioner, there are a couple of rollers and bolts in there to replace as well. Also do the waterpump as I mentioned a few posts back. If ya want to shoot me your vin, I can get ya a list of parts. I understand that there is a company out there that makes an aftermarket kit that extends the T-belt service intervals to 100k like on the newer TDi.
Old Mar 22, 2007 | 01:45 PM
  #80
Diesel-Dan's Avatar
Yeah....lookin at this one.....
Old Mar 22, 2007 | 02:46 PM
  #81
That's the one!
Old Apr 11, 2007 | 10:48 AM
  #82
Diesel-Dan's Avatar
UPDATE....got the car fixed.....actually drove it into work today....Wife visiting me!! AND this thing ain't no Cummins!
ISSUE: Idler Pulley bearings were GONE and T-belt tensioner was completely backed off.
The guy pulled the belt off with his hand after he took the cover off. No tension on the belt and the idler had bearings scattered through out the timing case. Idler was also eating up the water pump. Belt look to have been done at some point. Paint marks on the housing and gear. BUT not done very well. Needless to say....im suprised it made it 3 weeks of my wife driving it and didn’t make any noise! The guy that worked on it said there was no abnormal noise!
No banged valves.....don’t know how...but the Tappets look fine....no cracks!
Old Apr 11, 2007 | 12:49 PM
  #83
John Faughn's Avatar
Thats why a lot of shops recomend [ no warentee with out recomended sevices ] putting in a number of parts [ each eng. may need or not some ]
every T-belt change , water pump , tensoiner , idler pully ect.
With service of T-belts going over a 100,000 + , and the other parts are moved or covered by the T- belt , if the customer thinks that they are being taken [ not that this isn't true sometimes ] when this come up .
As a shop the costumer may expect you to cover a new/rebuilt eng. because they did not want to spend the extra $30-100 .
This may or maynot apply to anybody , but I like both parties , shop/customer to look at each others view point when there is a desission to be made .
Old Apr 11, 2007 | 01:08 PM
  #84
Glad to hear it Dan! YOU ARE VERY FORTUNATE, that you did not bend any valves.
rbuchana
Jun 1, 2006 08:48 AM
manganos
Mar 17, 2006 12:20 PM
Goldenbear
May 1, 2005 11:08 PM
ramcummins
Mar 18, 2004 01:55 PM
Goldenbear
Jun 21, 2003 06:28 AM
