hi lift
hi lift
so I have a hi lift jack that I have used mostly for back in the day when I had a toyota pickup and 4runner that I did a lot of 4x4 excursions with. I havent had a chance to use the jack with the dodge yet, until recently, I was missing my floor jack and needed to pop a rear tire off, so I went to use the high lift, but I couldnt get the truck more than an inch off the ground before it started shifting over, and the jack was pulling into the truck, which was about to leave a big ol scratch and dent in the metal.
whats goin on? is it all the weight just throwin the jack off balance?
I've never had good luck with a hi lift jack not doing what your describing. Where were you jacking from on the truck? Do you have the larger sand pad for the base?
i was just throwin it in the hitch reciever, and it was pullin forward like mad. I dont have the wider base for it though.
Administrator/Jarhead
Take the tail gate off...
Dunno what to tell you. They suck, and are dangerous, but they have gotten me out of a lot of bad spots. I have taken a 2x8 and bolted it onto the bottom for more support.
And they bend too easy too. I usually put a piece of wood between the top of the lift and the truck. Saves from scratches. And the 4 ton rating is b.s.
I bent mine all to hell lifting the rear of a 3500 dump which only weighed in a 4 ton for the whole truck.
doomgaze
04-13-2006 01:21 PM
0425004x4
16
01-23-2006 06:43 PM
lucey
04-21-2005 09:53 PM
