Ford Truck wheel question - what fits?
Old Sep 8, 2005 | 03:03 PM
Dave88LX's Avatar
Sorry about the off-brand post, figured some of you would know though. I've been told (correct me if I'm wrong) that you can put the 8-lug Ford wheels on a Dodge, but you can't put the Dodge wheels on the Ford because of the center hole being smaller. Does anyone know where Chevy stands in this? Anyone know what size the Ford middle hole is supposed to be? I found some 8-lug wheels in the JY, I need some for my F-250, but I need to know if they're Ford/Chevy/Dodge...
Thanks!
Dave
Old Sep 8, 2005 | 03:19 PM
Tiny's Avatar
I believe pre 1999 Ford rims were interchangeable with ours, but in 1999 they went to the 8X170mm bolt circle. Not sure about the center hubs.
Old Sep 8, 2005 | 03:37 PM
Palmetto_kid's Avatar
Tiny is right. Ford '99 & up will not interchange with dodge. '97 and older will though. I know becuase I have them.
79 ford
99 ford
98 dodge
Old Sep 8, 2005 | 04:06 PM
suzukiZrider's Avatar
the reason for the dodge rims not fitting on the ford is due to caliper clearence they will rub on the inside of the rims the newer chevy rims wont fit on either the ford or dodge without center hub hole modification so heres basically what will work any Pre-99 ford rim will fit on your truck but the factory dodge rim will rub on your caliper i beleive the gm rim will fit with the center hub hole modification
Old Sep 8, 2005 | 04:54 PM
TTHA33's Avatar
You are absolutely right
Valv
Jan 31, 2008 10:45 PM
Redliner
14
Mar 30, 2007 08:17 AM
jdimig
Jul 13, 2003 01:45 AM
Dodgezilla
17
Jun 12, 2003 11:38 AM
commando
Nov 16, 2002 04:43 PM
