Electric Fuel Pump Gurus
Old Jul 28, 2009 | 11:38 AM
irocpractice's Avatar
Task,to remove contents of fuel tank.Problem,using a drain plug is not an option.Will an electric fuel pump(Holly Blue Top) do the job?Details,you knew this was not straight forward didn't you,I have to insert/thread the suction 5/6 feet thru the filler down into the tank and pump out 45/60 gallons.So,are electric pumps pullers or pushers?Any other ideas?
Old Jul 28, 2009 | 12:39 PM
D2 Cat's Avatar
It's do either for 60 gallons!
Old Jul 28, 2009 | 09:03 PM
Equalizer 2's Avatar
Yes, you can shove 6 ft of hose into the tank through the filler and pump your fuel out. It is a lot cheaper if you do it and have somewhere to put the fuel. Please don't ask how I know. Electric pumps are pushers but that much won't hurt anything. The OEM transfer pump pumps a lot more than that and generally for a longer time.
I do use an old pump I have to pump the fuel from my 5 gallon cans into the tank when I use the cans. Takes longer than just pouring them but I don't have to lift and hold them while they leak down the side of the truck.
Old Jul 29, 2009 | 05:04 PM
Thanks guys
Diesel Girl
18
Oct 6, 2013 03:03 PM
cj5er
Dec 20, 2009 09:19 PM
duallydave
Jan 3, 2007 01:26 AM
TxDiesel007
Sep 9, 2006 07:37 PM
TexasHardcore
Jan 20, 2004 09:15 PM
