Dryer vent from middle of house?
Can I run the dryer vent hose down into my crawls space and back up into the furnace room then out the wall?
Distance is about 13'. Or should I go straight up through the roof? I'd rather not go thru the roof but will if it is the best option.
Thinking of doing some remodeling and moving things around.
A clean out in the middle might help as well.
Like he said with the pipe....But since I don't know if this will work for you but I have a junction on mine, in the summer it is blown outside, in the winter I have a lint trap and blow it into the house. being a single person the moister off a couple loads a week is good in this dry climate. Kind of silly to blow hot air outside since I paid to heat it.
I think going down into the crawl space is a recipe for constant clogging. Low spots collect moisture, which collects lint, and in a few months you have a soggy lint ball clogging the works.
a cleanout cover would be very beneficial. Mine is straight once it goes under the house so I can clean from the outside.
Moisture hasn't been a problem that I have noticed.
Yeah, 4" dryer vent, elbows (90 degree bends) = 5 feet of straight length. Tape the joints w/ duct tape and do not use sheet metal screws to attach. They collect lint and can cause a fire.
If you go with straight pipe put the seam up so moisture doesn't drip thru and slope it a little to the end so it will drain if moisture builds up.
Do not vent into the house if using natural gas or propane!
Kurt
Kurt
