CO Detector Question
Old Nov 23, 2005 | 10:16 PM
spunbearing's Avatar
Originally Posted by MedicShawn
PLACEMENT OF CARBON MONOXIDE DETECTORS IMPORTANT
Proper placement of a carbon monoxide detector is important. If you are installing only one carbon monoxide detector, the Consumer Product Safety Commission (CPSC) recommends it be located near the sleeping area, where it can wake you if you are asleep. Additional detectors on every level and in every bedroom of a home provides extra protection.
Homeowners should remember not to install carbon monoxide detectors directly above or beside fuel-burning appliances, as appliances may emit a small amount of carbon monoxide upon start-up. A detector should not be placed within fifteen feet of heating or cooking appliances or in or near very humid areas such as bathrooms.
When considering where to place a carbon monoxide detector, keep in mind that although carbon monoxide is roughly the same weight as air (carbon monoxide's specific gravity is 0.9657, as stated by the EPA; the National Resource Council lists the specific gravity of air as one), it may be contained in warm air coming from combustion appliances such as home heating equipment. If this is the case, carbon monoxide will rise with the warmer air.
For this reason, the makers of First Alert (R), the leading brand in carbon monoxide detector technology, suggests mounting the detector on the ceiling. This also puts the detector out of the way of potential interference, such as pets or curious children.
From http://www.homesafe.com/coalert/detect.htm
Good post Shawn. I sometimes forget that everybody doesn't do this stuff for a living and I leave info out. When I say 4-6 feet from the appliance I am referring to appliances enclosed in a confined space with a gasketed door and the CO detector should be installed on the return air side away from the combustion air openings. The 15 foot rule would apply to appliances in unconfined areas where the combustion air could escape and trigger a false positive upon startup.
Old Nov 24, 2005 | 02:34 AM
chaikwa's Avatar
Yeah Shawn, really good post! I've been teaching fire safety almost 20 years now, the last 3 on a full time basis, and I learn, (or RE-learn!) as much stuff right here from you guys than I do from some of the continuing ed classes that I attend!
THANKS!
chaikwa.
Old Nov 24, 2005 | 05:40 AM
Chrisreyn's Avatar
Darn it.. I was hoping to do this the easy way and just wire it up to an existing outlet.....
Now I gotta fish wire to a spot near the ceiling and all......
Can't I cheat just a little??????insert whineing smiley here
Old Nov 24, 2005 | 08:06 PM
MedicShawn's Avatar
Or you could mount one in an outlet and buy a ceiling mounted model.
ppsi
Aug 4, 2005 09:28 AM
Bob Berends
Apr 19, 2005 08:56 AM
Bob Berends
Apr 10, 2005 05:32 PM
Chrisreyn
Sep 7, 2004 09:41 AM
BASSMAXX
22
Apr 27, 2004 05:53 PM
