Super Flow Lie Detector In Greeley, Co.
Old Mar 27, 2005 | 06:00 PM
Bob Berends's Avatar
Thumbs up Super Flow Lie Detector In Greeley, Co.
We are having an all diesel dyno day in Greeley on April 16th.
Lie Detector Plans
This is a rough plan for how we will run things at the dyno. The rolls turn at 8AM. (They stop when I drop or everybody got to run.)
1)Trucks are run first come first served. You sign up when you get here and get your number. Put that number on your front and back window (like at the drags). Watch the line at the dyno. If you are at the dyno staging line when it is your turn, you are on. We will consider the dyno staging line to be about 5-6 trucks long. If you miss and the numbers pass you, you go to the end of the line that is staged at the dyno. Similar to NASCAR starting at the end of the longest line. This is the most fair way I can run this and not have to have you babysit your truck in a 25 truck line all day. If we are running #7 and you are #27, you may have time to ride around the block with someone else. If you are not there for your number, you go to the end of the longest line. It will not punish the guys who want to wait in line or the ones who are legitimately behind you.
2)The trucks will be given three (3) good pulls on the dyno. We plan to make all the runs in direct gear. This will not add gear multiplication or loss to the runs. You may have all the pulls the same or turn your boxes, etc up or down as you see fit between pulls. The computer has the ability to record your runs as fast as we can make them. You may be in the truck with me during the pulls. It feels cool to have your power tied down.
3)The runs will be made with the eddy current absorber on. That means your truck will build boost like, or better, than you make on the road.
4)If you have an auto trans that will not hold any single gear or TQ converter lockup, we are still working on getting the runs to give data with a shift in the middle. If you can make it hold a gear, tell me how when you get on the rolls. It will be better for all.
5)When your runs are over, please get out of the staging area so that we can get to the next truck. Your runs will be saved and very easily given to you (printed) in a few minutes after you park your truck. We really want to run a BUNCH of trucks. We thank you for your help with lineing up and clearing out.
6)When you are in the staging line, make sure that you are checked out to have the tape on the harmonic balancer so that you get a torque reading. We may have to paint your balancer to make things work properly. Flat black is best if you want to come prepared.
7)It is your responsibility to be sure your truck has oil, water and proper air pressure in the tires. We don't want any flats to remove at the last minute.
8)Duallies may or may not fit with the wheels in place. Each roll is 28" wide and there is just 28" between the rolls. Check yours out. If you do not fit, lets get something off so you do. Put your wheels back on after you get out of the staging area.
I think this is going to be a lot of fun
We will have a lot of volunteer help. Please be kind to them. It's a dirty job, but somebody has to do it.
Old Apr 1, 2005 | 07:23 AM
TTT
Is anybody over here coming, or are you all beating a ?
LaserBob
Old Apr 1, 2005 | 09:31 AM
BarryG's Avatar
Bob I plan on being there. How about some directions? I may or may not run not sure yet. By the way my Rasp showed up. So I am just waiting on the silicone hoses will call today to get an eta on them. Will be calling you for some shop time for the turbo, hoses and rasp as soon as I have them all in hand.
Old Apr 1, 2005 | 11:52 PM
The address is 404 8th Ave, Greeley,Co.
Hwy 85 north to 5th street.
Turn left (west) to 8th ave.
Turn right (north) one block on the right side. the building in the rear of the property.
Bob
Old Apr 3, 2005 | 05:42 PM
yzfr6's Avatar
I'll try to make it . Is there a cost, or is it free?
Old Apr 8, 2005 | 07:37 AM
Not many guys on this thread.
I think we are going to have a good crowd. Come on down and play or watch.
Cost is $40 for three good pulls and printouts of the runs, graph and data sheet. They look nice.
LaserBob
Old Apr 8, 2005 | 09:22 AM
Raggs's Avatar
I'll be there thanks for the info. . .
raggs
Old Apr 10, 2005 | 05:32 PM
Pics of GAM SuperFlow Dyno
If this link works you can see some pics of GAM's shop and some of their equipment along with the Lie Detector
GAM Racing Engines
LaserBob
LUKE-MM-PULLER
Aug 27, 2011 02:39 PM
Stovetop535
Apr 6, 2009 09:24 PM
Bob Berends
Apr 19, 2005 08:56 AM
