Butane Refilling ???
Old Jan 13, 2008 | 11:12 AM
BearKiller's Avatar
Question Butane Refilling ???
I bought one of those pencil torches at Harbor Freight; 99-cents well-invested, and I should have got one years ago.
What is the proper method for refilling butane reservoirs ??
Should the can of butane be held tip up, or tip down ??
Thank you.
Old Jan 13, 2008 | 11:52 AM
jrs_dodge_diesel's Avatar
On my butane soldering iron, the fill port is on the end. I have to hold the butane can inverted (upside down), and the fill port facing up. I then engage the nozzle of the butane can and push down to start the flow. It's at capacity when it starts to spit and bubble back out.
Really what you are doing is transferring liquid butane from one tank to another. That is why the can must be inverted.
Hope this helps.
Old Jan 13, 2008 | 04:21 PM
BearKiller's Avatar
Hope this helps.
So it's LIQUID and the can needs be upside down.
Thanks; that's a lot more than I knew before.
Old Jan 13, 2008 | 06:49 PM
Butane is the same thing as propane except the boiling point is much higher. It's petroleum gas kept liquid under pressure.
Old Jan 13, 2008 | 11:35 PM
BearKiller's Avatar
Spoken like a true gas-man.
Silver R/T
Aug 26, 2010 09:02 AM
Robbsdpower
Apr 21, 2008 07:05 AM
jj3500
15
May 18, 2007 10:54 PM
