Refilling NV5600
Old May 15, 2007 | 10:17 PM
jj3500's Avatar
Refilling NV5600
Is there an easier way to fill this up? What I wound up doing is undoing the plastic shroud surrounding the shift ****. I had one of those funnels with the long snake like tube.
Good thing this isn't one of those regular maintenance items.
Old May 15, 2007 | 10:29 PM
Homestead's Avatar
Easiest way is to pull the console and pop the shift tower off and pour away.
Takes a few extra minutes but there is no mess.
Jeff
Old May 15, 2007 | 10:36 PM
blackdiesel's Avatar
Registered
put an extra qt. in while you at it
Old May 16, 2007 | 03:47 PM
Homestead's Avatar
Yes, definitely an extra quart for sure. I run a full 6 quarts in mine and the only way to get it all in is thru the shift tower.
Jeff
Old May 16, 2007 | 05:35 PM
RAFTEN's Avatar
So is 5 quarts the factory spec?
Old May 16, 2007 | 07:04 PM
Registered
that's right
Old May 16, 2007 | 08:08 PM
jj3500's Avatar
I assume that putting in that extra quart won't harm anything.
Old May 16, 2007 | 08:09 PM
Registered
come on!! would we lead you wrong
Old May 17, 2007 | 12:19 AM
Sask's Avatar
If you're running a 4x4, 6 quarts or more in the NV5600 may cause a blow-through at the rear seal at the transfer case join. I've seen it happen, and the dealer in my area has seen it, too.
I've got a Fast Cooler on one side, and an Eaton tranny filter on the other side of my 5600 - both mounted where the PTO plates were. Between the two, that's an extra quart capacity - for 6 total. Perhaps that's the "safe" way of stuffing a bit more fluid in there. Cools a bit better and cleans a bit, too.
Old May 17, 2007 | 12:27 AM
Philabuster's Avatar
Jeff
Not true. You can fill the tranny with 5 quarts through the fill hole, plug it, and fill the remaining quart through the top bolt of the PTO cover.
Old May 17, 2007 | 07:10 AM
Homestead's Avatar
I've run a full 6 quarts for over 5 years and 110,000 miles and have had zero leaks or "blow throughs" That's the first I have heard of that and I know a ton of people running the same amount of oil.
I'm sorry but you won't get 6 quarts in using the top PTO cover bolt, believe me I've tried all kinds of angles and tilts to do it threw the cover bolt and you can short of laying the truck over on a 45 degree angle.
Jeff
Old May 17, 2007 | 09:32 PM
JasonblkZ06's Avatar
I refilled mine with 5 about 5K ago, should I add another quart?
Old May 17, 2007 | 09:36 PM
BCB's Avatar
BCB
Jeff
well judging from your avatar thats not a problem for you... sorry couldn't help it
i don't really see the "blow out" happening cause the frist time i filled my 5600 i put 7 quarts in and it just blew that extra quart out the vent... all over the truck
6 is fine and it seems to shift better.
Old May 17, 2007 | 09:54 PM
I just joined and haven't listed all my mods, no where near some of you guys but is is far from stock too.
Old May 18, 2007 | 10:47 PM
SIXSLUG's Avatar
Running 6 through the top cover for a year now. No leaks. Seemed to shift better and apparently helps lube the rear most bearing in these trans'.
