'90 mariner 15 hp outboard help
Well, I can't be the only guy out there that has a '90 15Hp Mariner outboard motor.
When looking at the back of the motor, up under the engine are there two exhaust ports or just one?
I suspect there are supposed to be two and my motor has a manufacturing defect in that the second hole wasn't drilled all the way through.
Thanks for the link,
I know it shouldn't make too much of a difference at high speed but at slow speed it is kind of the difference between breathing through one straw or two... Apperantly the motor was having a carbon issue. so we'll have to see if drilling it out helps....
Originally Posted by jrs_dodge_diesel
westcoaster, by any chance do your exhaust ports point down?
Yes, they are pointed at the prop and are part of the leg. it's a bump on the housing up at the top.
Ok, because last night a saw a 15 HP Mariner last night on a boat and its ports were pointed down. It had the two ports but like yours only used one of them. On;t one had the black streak where exhaust gas came out.
