1985 FORD F150 brakes
Old Nov 10, 2007 | 02:30 PM
rootercycles's Avatar
Hey everyone,
I know that this is a Dodge forum, but I am having an issue with my old FORD work truck. I am completely baffled by a brake problem I have with my truck. I completely lost brakes yesterday. I looked in the new master cylinder I replaced this year, and found the front reservoir completely empty. I traced all of the lines back only to find all intact. I bled all four brakes twice. I test drove the truck and the problem persists. Could my brake booster be bad? I can't figure out where the brakes would be leaking if I can't find a leak within the lines. I did notice that when I had my son step on the pedal, brake fluid leaked out past the gasket of the cover on the master cylinder over the front chamber. I am going to start with bleeding the system again, but am baffled by this problem. I did not find any leaks arond the front calipers, or from behind the rear drums.
Thanks for any help you can provide!
Old Nov 10, 2007 | 05:28 PM
dj_souvlaki's Avatar
if its leaking out of the master than thats probably your problem. how do you're wheel cylinders look?
Old Nov 10, 2007 | 06:28 PM
cbtumedic's Avatar
Sounds like the master cylinder is leaking out the back, i had rebuilt master cylinder do this to me a couple months ago, started leaking out the back before i even got a chance to bleed the brakes. good luck
Superduty
Oct 27, 2005 01:57 PM
hotdram
Mar 24, 2005 12:33 AM
canucktrucks
Jul 14, 2004 09:09 PM
cp
Sep 17, 2003 09:53 PM
