Alberta Dyno and GTG
Went to the car show, it was ok, some neat stuff. Looked at the new dodges with the 6.7 and the 6 speed auto, cant wait to try one out. Some weird electronics under that hood. There was one that was hooked up to the turbo, is the new engine got a variable vane turbo?
Kevin
Kevin
Actually to be technical, its not Variable Vane but rather VGT or Variable geometry turbo. Imagine a turbo that has an exhaust housing that changes from 9 cm2 to 20 cm2 with the computer at the helm.. Ah, spool up without problems breathing at higher RPM and load..
Also the VGT has about 3 moving parts instead of the infinite amount on the GM and Ford turbos.
Let me know how it goes Tate, there are a bunch on the lot here I just don't have the time to go.
Anyway, took on of the C&C trucks out. Quiet, and a real soft clutch pedal. After driving the 07, I had a hard time pressing the clutch down in mine. Pedal effort was probably half in the 07. Had a hard time finding reverse, but eventually found it. Gotta move the shifter a long way. I really don't like the shifting of the 6-speed. Guy said it will loosen up over time, but he hasn't seen any with enough miles to know for sure. It wasn't overly exciting to drive. Granted, my truck has some work done to it, but this truck didn't push you back in the seat at all. Throttle didn't seem terribly linear either. Had to use a lot of pedal. I don't know if that is because of torque management, or what. Had to watch the tach to know when to shift, couldn't hear the engine enough to tell if it was working, or revving. Quiet all the way to 3200 rpm. I never really lugged it to see what it would do in the lower RPM. Doing 50 km/h in my truck in 4th, I'm around 1100 RPM, this truck in 5th was still close to 1500. 100km/h in 6th was over 2200 RPM. Said it had something like 3.92 gears, but I'm guessing it had 4.10s. I didn't think they were available with 3.92s. I will say, for a 1-ton without any weight on the back, it did ride fairly nice. A heavy flat deck would make it ride even better. Anyway, in summation, I'd save my money and just keep plugging with 98. Especially when he said the cheapest one he can remember was $55k! He's getting me a quote on a base 2500 4x4, see what it comes to.
BTW, the exhaust brake isn't enabled until the trucks are sold. He said they don't want people playing with it.
Well, the dirt bike i was supposed to get got scrapped.... soo this turbo's gota go (stg 3 jammers and centerforce twin disk clutch in the mail studs will be orderd next week) i dont wana spend a big amount for a turbo so silver bullet is not for me... would like to push 45-50 pounds. I have been looking at the piers HX40 better but i still dont think its safe, BD diesels super B single. maby someone's got a used (gently used) but would like to know the locals oppinons before i go ask the southern boys in the real 2nd gen forum.
HTT makes a good turbo. The HTB2 is a nice unit, but I have read a bit about surge down in the Rpm range. HTT also has a pretty nice upgrade program and I have heard really good customer service. High Tech Turbo
I have been putting my eye on a PS62, but today I had a offer on a S300 (Switzer turbo that the PS turbos are made from). So it looks like I am going with the S300 (BD's Super B turbo is a rebadged S300). Got it used from a guy I know in the US...Should be here next week...
I have seen the s300s and they are awsome units, i just wonder cause i have heard these only support up to 400hp... so around 40 pounds, i would think that you would start blowin hot air in the high rpm's?????
Is edge's jammer BB turbo in with the s300, I get special treatment at edge so maby this may be a better route for me.
...........OK maybe I should expand a little.
