Never ending Thread XI
Thanks, ... Now should I do the Airdog at the same time???? They state I should replace the feed pump and filter at the same time....... $950 is one thing, but an additional $500 is another......
is the holley still working? as long as you have a working lift pump and a fuel filter i wouldnt worry about it. the airdogs are nice, but no need to remove a working system to replace it if you dont have the extra coin to throw at it.
I've been real busy with David's Football practice and working lots of OT.
Fixing 34 of the 37 USCG pumps that Bobby said they probably wouldn't fix. Plus i've got my other customers pumps piling up for inspection and repairs.
Jason try http://fixinrams.com/. He has Vacuum pumps and parts. That's where most of us get our Vacuum pump seals from.
Anyone know what size the trans cooler hard lines are in the autos? I need to get some slip fittings and probly 2 90's or something to loop the lines that went to my heat exchanger. I got the in line tee for a temp sensor a while back and now that I have a perfect opportunity to put it on, I cant find it.
Lost motivation the past 2 months on the truck but im tinkering away in the evenings here and there. Got the fuel lines and power steering hooked back up tonight. Tightening the engine mounts and putting the starter on another night. One day it will live again.
I need a new torque convertor.... Sniff...
Whats yall input on just a torque convertor install? Tranny is in good shape with 20k on it. no metal or dirty fuild. Just a shudder under heavy loads.
I have $1k to spend on it.
Thanks
Thanks
Well there's quite a few to choose from. Goerends, Garmons, DTT, Suncoast....................
I have been pounding on my TCI from Jegs for 4+ years and it's still holding on strong. It was only $500. But i also have a good VB too. Gotta get those stock line pressures up with a good VB.
Is it still the stock converter? The TCI Maximizer that i have is the billet front cover. I figure TCI has been making race trans for ever so they should know what they're doing.
