won't crank
Old Oct 26, 2008 | 12:08 PM
spruce's Avatar
won't crank
2006 dodge 1 ton mega cab cummins. automatic
when you turn the key to the crank position, engine will not crank.
voltage at the batteries is fine. everything works with the key in the run position.
After several attempts you will here the starter start to engage, and after a few more attempts it will start to work again and start the engine.
I am thinking ignition switch?
Does this model have a adjustment/rod dowm in the sterring column?
thanks
Old Oct 26, 2008 | 12:31 PM
Smokee's Avatar
Sounds like a bad connection on either the battery cable or the starter. Feel for a Hot connection after you have tried to start.
george
Old Oct 26, 2008 | 12:52 PM
Number47's Avatar
check your fuses Mopar used a ASD fuse which stands for Auto Shut Down if that fuse pops no crank no start
92smokin blacky
Feb 28, 2011 02:36 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
