crank no start
crank no start
Alright its been getting chilly out here the past two nights, and low and behold to try to start and nothing. It cranks and cranks, rananananananannnna, and nothing. Ill let it sit cycle the key twice more and try again, rananananananananana, nothing. Then a third time, ranananananana, some go go pedal, (to the floor) and pop pop pop pop pop, then smoothe as silk idle..... I dont get it each time i crank it is for a good 45 seconds.....
here is what she is: 100 plate full forward, no afc, 370 injectors, 16* timing (checked it yesterday to make sure no slippage).... any one have any ideas? this is getting old on me... its oly 48 degrees right now and she dont start...... ***!!!!
Had the same trouble on my 03 this morning- turns out my batteries were strong enough to turn the starter but not start the truck. I figured this out by plugging the block heater in for about 45 min and it started right up.
Booster
Try shooting some WD-40 into the intake. There are some 1/8" pipe thread plugs which people use to hook up a boost gauge located on the side of the intake, above the pt7100 pump. Unscrew one of these and give a 2 second shot and see what happens. It burns like diesel, flashpoint wise; so if it fires right up you have a problem of not getting any fuel. If it doesn't.......the problems are a little more $$$$$ cd
my grid heaters are half and half, one side is dead the other is good. only one relay is currently working. also the fuel pre heater hanes is mia and the seno is melted....
It's possible for it to suck in air at the fuel heater if it's melted or damaged. Unhook the electrical connector from the element and see if it's wet with fuel there.
found two leaks, number 5 injectors seeps, and then the lines on the top pof the filter were loose and sparaying a mist this morning. the starting was getting sworse and worse so i figure that they were vibrating loose
92smokin blacky
Feb 28, 2011 02:36 PM
CoolumConst
Oct 11, 2008 10:00 PM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
