White Smoking at Idle
Old Jul 12, 2007 | 08:15 PM
JamesA's Avatar
My truck smokes white smoke while idling. No white smoke under any other throttle conditions. The idle smoke is pretty excessive for idle, but once I touch the throttle, it appears to stop. If I rev the engine, it stops for only a few moments then starts again. It starts as quick as a traffic signal wait. Oil change did not help. Anyone with IDEAS?
_______________________
03 2500 QuadCab Cummins, 48re Auto, Predator Module. K&N FIPK, 150,000 Miles
Old Jul 12, 2007 | 08:24 PM
Dr. Evil's Avatar
What year is it?
Hard starting when warm?
Old Jul 12, 2007 | 08:28 PM
txfiremedic's Avatar
Fill out your signature so we can tell what you drive, what year, any mods, etc. Before any of that, white smoke normally indicates a bad injector/injectors. Have you checked your oil? Smell like diesel?? Just a guess.
Old Jul 12, 2007 | 08:29 PM
Justwannabeme's Avatar
DTR Mom
Wink simple stuff even for new technology
white smoke is nothing more than air in the lines....
possible causes too can come from :
some or all bad glow plugs
plugged or restricted return line
insufficient fuel supply
some or all injectors bad
incorrect pump to engine timing
low compression
bad injection pump
rarely- incorrect engine timing
howz Dat?! sorry for the expensive scary stuff but good to check them out an blow air through the lines.
a cracked gasket can do that too especially in what you describe....
Old Jul 12, 2007 | 08:37 PM
t-boe's Avatar
Two injectors bad for me. They also did a white smoke reflash. It helped some but didn't get rid of it entirely. I start using some 2 stroke in my fuel and it doesn't do it anymore. I'm starting to suspect the ULSD being the culprit. I don't have any evidence supporting that suspicion other than it quite doing it RIGHT after I put some in.
Old Jul 12, 2007 | 09:03 PM
JamesA's Avatar
Not hard to start. Usually within 5 seconds
DODGE4X4
Aug 21, 2007 07:41 PM
seabee
Jan 1, 2007 02:16 AM
Ripper406
Jul 9, 2006 09:26 PM
cumminsdriver635
Mar 6, 2005 10:54 AM
