Wheel bearings on 1999 Dodge Ram
Old Nov 8, 2004 | 10:51 AM
Flatty's Avatar
I have my 1999 Dodge Ram with the CTD. Well the front wheel bearings went out on this truck. I ordered some new ones from an online place and theyw ere the wrong ones. Totally not their fault, but I need the RIGHT bearings. Can my truck have ABS rear ONLY?!?!?!?! I ordered the bearings for the ABS rig, and when I got them, the bearings I ordered had the ABS sensor, but Mine did not?!?!?!?! Can this be the right one?
Timken HA590020
Or is it this one:
Timken
SK580100 and SK580101
PLease HELP
Dima
Old Nov 8, 2004 | 10:58 AM
Mcmopar's Avatar
Fill out your sig, need more info- 2wd 4X4 ?????
Old Nov 8, 2004 | 11:01 AM
Flatty's Avatar
This is a 4wd with the 8800lb rating. The truck has the Dana 60 up front.
The bearing I got has an ABs sensor coming out of it. The ones on my truck DO NOT!!! I know I have ABS beacuse the light is on in the cab. The rear sensor on the rear axle is blown out (Just went out). So I know I have rear ABS for sure, biut not really sure about the front.
Does anyone have a good place toget the bearings?
DIma
Old Nov 8, 2004 | 11:05 AM
Mcmopar's Avatar
If you have ABS in the front there will be wires running down by the brake line and attaching to the hub assembly. I am positive about the 98, and pretty confident about the 99.
Old Nov 8, 2004 | 11:09 AM
Flatty's Avatar
When I pulled mine apart on the drivers side, there were NO electrical components. There is no plug or anything for the ABS sensor at all. IS it possible to have rear, and not front ABS?
Dima
Old Nov 8, 2004 | 11:16 AM
Mcmopar's Avatar
Yes
Old Nov 8, 2004 | 12:22 PM
dodgeram's Avatar
my 99 only has rear abs .........rear wheel abs was standard, 4 wheel abs was an option
Old Nov 8, 2004 | 08:38 PM
jdeereboy's Avatar
Hey Dima, Where did you get the bearings from? I sure could use that RH bearing with the ABS sensor.
Old Nov 9, 2004 | 09:22 AM
infidel's Avatar
Open you hood and look straight up.
There will be a tag that says if you have 2 or 4 wheel abs.
Old Nov 9, 2004 | 10:13 AM
Flatty's Avatar
I am sending them back because they are the wrong ones. I got them from www.discountautoparts.com The # is 1-877-328-8672 Ask for Joe Belmonte and tell them Dimitri sent you. They were about to beat the local places by over $100 eachside. They have no shipping (ground) and no tax.
steafe
15
Jan 21, 2011 08:44 AM
jsteezy1290
Oct 8, 2005 11:09 AM
Floyd
Jul 26, 2005 09:18 AM
Floyd
Jun 7, 2005 01:44 PM
Serene
Nov 15, 2002 03:48 PM
