Water pump?
Old Dec 31, 2002 | 09:47 AM
kittoe1's Avatar
Water pump?
Was driving home from work this morning, check engine light came on and temp guage jumped to 210. The serpentine belt came off and water was dumping out from front of motor. Does this sound like water pump went out, and if so , has anyone replaced and know cost.
Old Dec 31, 2002 | 10:25 AM
Alan_Reagan's Avatar
Re:Water pump?
Find a water pump here for about $68.<br>http://www.dieselinjection.com/products.html<br> Just scroll down. They list for $120 from Cummins if I'm not mistaken.<br><br>It could be the water pump. Is it seized or something that made the belt jump off or did it just overheat? If it seized or the bearing has play, it could cause your problem.<br><br>Usually you get a warning by water coming out of the weep hole on the side of the water pump.<br><br>
Old Jan 2, 2003 | 04:04 AM
kittoe1's Avatar
Re:Water pump?
Looks like the bearing seized, thanks for the info. on the pump. I have replaced my share of water pumps on gasoline motors but never a diesel, looks about the same. I guess Im about to find out , thanks again.
Old Jan 2, 2003 | 09:59 AM
Re:Water pump?
Not the same. This one only has two bolts and you don't have to disassemble the front of the engine to get it off.
ted_pulliam
Oct 15, 2009 08:24 AM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
