Wastegate solenoid-p0243
Old Jan 27, 2010 | 08:55 AM
2manytoys2's Avatar
Stock 04.5. automatic. I got a code last night when starting and tried to clear it but it comes back. I am going to check the wire issues today. Can I drive it like this? I read that you can bypass the wg, is this good? Can I put a fooler inline so the light goes off. Should I get the right part from Dodge? Thanks for any replies.
Old Jan 31, 2010 | 09:50 PM
BigIron70's Avatar
Cummins Guru
code P0243-WASTEGATE PRESSURE CONTROL PW, change #5 wastegate control valve
Turn the Ignition on, engine not running.
Disconnect the Wastegate Control Valve harness connector.
Connect an incandescent test light across the supply and driver pins at the
NOTE: The ECM will perform a self check of the circuit after approximately
30 seconds, which should light the incandescent test light.
Does the light illuminate brightly after 30 seconds of being connected?
Yes ! Replace the Wastegate control valve.
No! Check for broken wires
1 - Turbocharger Exhaust Elbow
2 - Turbocharger
3 - Oil Supply Line
4 - Turbocharger Compressor Outlet
5 - Electronically Controlled Wastegate Command Valve
6 - Turbocharger Oil Drain Tube Bolt
7 - Turbocharger Oil Drain Tube
8 - Turbine Housing
trik396
Apr 28, 2011 10:50 AM
tyson686
Dec 13, 2010 09:57 AM
polk5295
Oct 12, 2010 02:56 PM
Swamp_Donkey
Feb 16, 2007 10:59 AM
tristan21
0
Jun 12, 2006 03:00 PM
