Getting p0480 (cooling fan) and p0243 (wastegate pressure) codes.
Old Mar 7, 2010 | 03:13 PM
polk5295's Avatar
I have owned this truck, see sig, for a couple of weeks and it was stock when I purchased it. I loaded my Smarty on it the same day I bought it and have only had it on setting 5. Today I installed a boost and egt gauge. During the first drive I got 2 codes: p0480-cooling fan 1 control circuit and p0243-wastegate pressure control pwm. When I rolled on the throttle I was only making 24-25 psi. I thought that it might be the Smarty causing the codes, even though it hasnt over the past 2 weeks, so I removed it. With the truck back to stock I still got the same codes and the same boost levels.
During the research I conducted my problem seems that it might be a bad wastegate solenoid.
Would a bad wastegate solenoid cause the cooling fan code as well? Do you guys have any other ideas or things that I should look for?
Thanks in advance...
Old Mar 7, 2010 | 04:35 PM
Rpainter's Avatar
I got those codes once I cleared them checked the wiring around the fan,the harness that goes by the ac compressor. Found nothing but it has never came back??
Old Oct 12, 2010 | 04:41 AM
Venom617's Avatar
I just got the same code on my truck. No mods either. Later in the day check engine light went out. Any possible idea other than wire or fan blade/clutch?
Old Oct 12, 2010 | 01:47 PM
NavyDood's Avatar
P0480 comes and goes on my truck. Has been doing it for the past 3 years. I ignore it since the Fan works like it should.
Sorry, don't have an answer for the P0243.
Old Oct 12, 2010 | 02:56 PM
cincydiesel's Avatar
Mine fan code has been showing for a couple of years and works just fine. As for the waste gate, just clamp off the rubber inlet hose. Ran this way for about 70,000 miles with no issues.
tyson686
Dec 13, 2010 09:57 AM
2manytoys2
Jan 31, 2010 09:50 PM
upjeeper
Jan 26, 2008 09:36 AM
tristan21
0
Jun 12, 2006 03:00 PM
mopar2ya
Apr 1, 2004 06:42 AM
