Squealing Noise
Old Oct 5, 2010 | 10:14 PM
Devinraptor's Avatar
Squealing Noise
My truck recently started a weird squealing noise a couple days ago. I will try to describe the sound. It sort of sounds like a valve tap or exhaust leak in combination with a belt squeal. I only hear it at high boost levels, usually when I take off fast or take off with a heavy load. I appreciate any help
Old Oct 6, 2010 | 05:03 PM
tryNto's Avatar
Check all your Boost hoses for leaks, make sure all the clamps are TIGHT...
Old Oct 12, 2010 | 03:44 PM
john40's Avatar
Trynto is right. I had a similar noise when I had a '98 12v. It sounded like a very bad water pump. I ultimately tightened the v-clamp on the intercooler side of the turbo to specs (72 in lbs) and the sound went away. John
Smkn600CTD
May 22, 2012 07:21 PM
trik396
May 20, 2009 10:15 AM
Silver04.5
Jan 4, 2009 02:45 AM
Lightman
Jun 28, 2007 05:22 PM
russ300h
May 13, 2006 07:23 AM
