turbo rings how to take them off
mia
If you look close you can see a ring around the outside edge of the crome , about an 1/8" and follow around till you find 2 ears with holes or notches that you can get ahold of with a pick or, small screw driver and pry inwards and pull out of grove, then you should be able to just tip the crome ring out, go to the user cp and fill in the info on your truck so that we can help with ?.
Originally Posted by Saxet Nomad
Turbo Air Guide
Thanks
So should I keep mine in or take it out with the ring? I did open the airbox up in the bottom but see no need for more noise and no gain.
ahire
13
10-17-2008 12:50 PM
12VRoush
10-15-2007 08:00 PM
1320
03-08-2005 08:56 PM
