turbo oil drain
Old Jul 9, 2005 | 12:07 PM
FrdRdnk's Avatar
turbo oil drain
Supposed to get my hx35 today so i was gathering some tools for it this morning. What size are the bolts for the oil drain on the H1C, 11mm is to big but 10mm to small, same with 7/16 and 3/8. I think I can get the two bolts off with pliers, but it's a tight fit in there.
Thanks
Sam
Old Jul 9, 2005 | 02:26 PM
Sam, it is 10 mm. I've had several off, and they were all 10 mm.
Old Jul 10, 2005 | 03:23 PM
FrdRdnk's Avatar
Went out of town yesterday evening, no turbo yet but I'll try 10mm again and let ya know. Thanks
Old Jul 11, 2005 | 08:37 AM
FrdRdnk's Avatar
Tried again and the bolt on the engine side takes a 10mm perfect like you said dave but I can't get it on the fender side. I guess something was done to it in the past that messed up the head. Anyway, I think I can get some pliers on that to get it off since it's a little more open on that side.
Old Jul 11, 2005 | 09:04 AM
Saxet Nomad's Avatar
You may try an open end wrench instead of a socket...maybe the bolt is too close to the drain pipe...???
Old Jul 11, 2005 | 09:16 PM
FrdRdnk's Avatar
Tried it too, but thanks. I'll think I'll be good with pliers, I hope, and then take a better look at it once it's out.
pistazie
ABDTR #5
Apr 30, 2009 08:16 AM
klx650a2
Jan 10, 2008 12:08 AM
1ST GEN.
Feb 3, 2005 12:00 AM
AZGEARPRO
Nov 3, 2004 07:53 PM
wooff
May 1, 2003 11:22 AM
