Truck wont Shut down 2003 CTD
Old Apr 7, 2011 | 08:01 PM
DODGER BOMBER's Avatar
So my buddy just called me and he is coming over and im looking for ideas were to start. He said before the truck gets up to full charging, it will shut off but once it goes over 14V on the gauge it wont shut down. Now yesterday he said it was kinda speratic and it shut down this time but not this time and then if he moved the steering wheel it would shut down. And some times it would just shut down on its own(key off,but still running). Now he was going to take it to the dealer but they had no clue and at 105/hr they said it could take a while to fix the issue. Any help would be awsome of were to start.
Old Apr 7, 2011 | 08:31 PM
cincydiesel's Avatar
Kinda sounds like a sentry key issue but I'm no means a mechanic.
Old Apr 8, 2011 | 10:34 AM
Thats what i thought too but we still cant figure it out. He might have to take it in i guess. Thanks for the help anyway.
Old Apr 8, 2011 | 10:44 AM
Okay this may be a really dumb question but he doesn't have a turbo timer does he?
Old Apr 8, 2011 | 11:28 AM
Nope completely stock. Nothing done to the truck but maintenance. He hauls a stock trailer just about every day. So he never did anything to the truck.
Old Apr 8, 2011 | 07:05 PM
firestorm's Avatar
If it's overcharging, it could be back-feeding voltage to the fuel system. I am still trying to figure out these new CR engines.
Old Apr 9, 2011 | 08:48 AM
Ya not sure. These CR dont have a fuel shut of selinoid do they?
Old Apr 10, 2011 | 08:35 AM
DieselLady's Avatar
No fuel shut off on the common rail. Sounds like a wiring issue if he can turn the steering wheel and it shut off.
Old Apr 10, 2011 | 04:35 PM
James Gunter's Avatar
Just a suggestion--check the wiring to the electrical part of the ignition switch, you`ll find it on the left side of the steering column. I`ve had to replace this switch 2 times for bad connectors. This is definitely a badly engineered item.
Old Apr 10, 2011 | 07:50 PM
Ok will do.
upchurch30
Sep 16, 2008 12:06 AM
Dufrain
Nov 9, 2006 08:18 PM
chromedome
Apr 10, 2004 10:46 PM
ts
Nov 4, 2003 10:32 PM
dsljunkie
Jan 4, 2003 09:45 AM
