Truck stopped cold
Old Feb 26, 2006 | 05:59 PM
Trinity's Avatar
Truck stopped cold
Need a little help, I'm using my Dad's '90 Dodge with a Cummins BT 5.9. It stopped cold on the highway yesterday, no hesitation. I've primed the filter/seperator. Worndering what's next, lift pump or injection pump. Is there an easy way to rule things out and try to fix it myself?
Old Feb 26, 2006 | 07:12 PM
crobtex's Avatar
I don't know a lot about 1st gens, but I think you're on the right track by starting with the fuel system. Have you checked the filter to see if it's clean, pressure...do you have a fuel pressure gage? Have you cracked an injector line to see if you're getting fuel to the injectors?
Old Feb 26, 2006 | 07:22 PM
Make sure you have power to the shutoff solenoid at the back of the pump. There ought to be 12 volts there when the key is on. It's not uncommon for the terminal just to fall off. If that's all good, throw a fuel filter on it and see what happens.
Paul S.
Mar 17, 2011 08:33 AM
wcbcruzer
Jul 9, 2008 12:56 PM
iker42
Aug 23, 2007 01:05 AM
roaming oregon
Jul 30, 2007 03:09 PM
bentwings
Dec 23, 2006 06:00 AM
