Truck possessed
Old Feb 8, 2009 | 03:05 PM
Panhead51's Avatar
Truck possessed
06 2500
Random, unstopable Panic alarms, tail lights coming on when door is closed, interior lights acting wierd. Any thoughts?
Old Feb 8, 2009 | 03:08 PM
82NDSNPR's Avatar
gremlins in the wires man
Old Feb 9, 2009 | 07:20 AM
1-2-3's Avatar
Just a plain ole guy
Is it under warranty? How many miles? Any mods?
Old Feb 9, 2009 | 07:25 AM
madhat's Avatar
Administrator/Jarhead
Wow... that's weird...
Disconnect your batteries for 30 minutes, before you hook them back up, press the brake and turn the key on... Maybe that will reset the computer...
Have you done anything lately to it?
Old Feb 9, 2009 | 09:00 AM
Panhead51's Avatar
Thanks, 50k, Still warranteed, no mods. Just trying to avoid a trip to the dealer.
Old Feb 9, 2009 | 09:01 AM
TreeFarm's Avatar
Someone mentioned similar (but not identical) problems because the battery in his key fob was bad. If madhat's suggestion doesn't help, try switching to your spare key and see if that makes any difference. It's an easy check.
Otherwise, check for loose connectors or grounds.
Old Feb 9, 2009 | 09:36 AM
Panhead51's Avatar
Thanks, hadn't thought about the key, even tough i sometimes have to get right next to the truck to unlock it.
Old Feb 9, 2009 | 09:39 AM
dozer12216's Avatar
I understand mounting a horseshoe in engine compartment will belay the gremlins for sure.
If you really want to kill stray signals made by mischarged circuits in computers, try this. Remove ALL battery connections. With key off short a positive and negative lead together for 1 minute. REMEMBER YOU ARE SHORTING THE CABLES, not the batteries. Normally you will get a small electric arc from the capicators(batteries) in the various computers. Upon reconnecting you will also get a arc as the capicators charge and various lights come on. At this point you have lost all adaptive memories in computers. Driving will restore memories from a normal starting point. JMHO
Old Feb 9, 2009 | 09:50 AM
Panhead51's Avatar
Wouldn't the horse shoe interfere with the rabbit's foot i stuck in the air cleaner? Maybe the voodoo doll of my ex in the glove box is causing all the trouble. I could try removing some of the pins. Now the cargo light is on and won't turn off.
Old Feb 9, 2009 | 11:03 AM
1-2-3's Avatar
My BIL had a 76 Chevy pickup that would wipe the windshield once about every 10 minutes. Every single component got replaced but it still did it for the 10 years he owned it.
smokin'joe
Jan 28, 2012 11:12 AM
silver_2000_tj
May 20, 2010 10:43 PM
Ton-O-Fun
Dec 28, 2009 02:10 PM
grandscapesllc
Apr 13, 2008 09:24 AM
spunbearing
Nov 16, 2004 11:51 AM
