truck is going crazy and it is throwing 4 codes
Old 07-03-2007, 08:34 PM
TexMexCowboy's Avatar
help my truck is realy going crazy. i turned it on and it mad a wierd noise. then i shut it off and it then it came back on with no problems. I checked for codes and it gave me 4 codes which are:
P0123
P1596
P1694
P1687
Old 07-03-2007, 08:45 PM
phox_mulder's Avatar
Only ones I found are:
P0123 Accelerator Pedal Position Sensor Signal Voltage Too High
P1694 No CCD Messages Received From ECM
If I had to guess, I'd say your APPS.
phox
Old 07-03-2007, 08:46 PM
what should I do?
Old 07-03-2007, 09:41 PM
crobtex's Avatar
Look in the "Tech Facts" above. The is one procedure for "re-setting" the APPS and one of doing the "Recal".
Old 07-03-2007, 10:57 PM
cool i will do that and then we will see what happens
Old 07-03-2007, 11:20 PM
ok reset the APPS but it is still showing the P0123 code but the others are gone
Old 07-04-2007, 07:04 AM
crobtex's Avatar
You may have to do the voltage adjust. Some are so far out of range they won't adjust, but it's cheaper to try than buy a new APPS assembly.
Old 07-04-2007, 03:50 PM
kool ill try that here pretty soon.
dodgecbr600rr
02-10-2008 07:55 PM
TexMexCowboy
01-11-2008 01:33 PM
RAT_03
04-01-2007 03:51 PM
Sarge1124
09-02-2003 11:02 PM
Quick Reply: truck is going crazy and it is throwing 4 codes
