truck is going crazy and it is throwing 4 codes
help my truck is realy going crazy. i turned it on and it mad a wierd noise. then i shut it off and it then it came back on with no problems. I checked for codes and it gave me 4 codes which are:
P0123 P1596 P1694 P1687 |
Only ones I found are:
P0123 Accelerator Pedal Position Sensor Signal Voltage Too High P1694 No CCD Messages Received From ECM If I had to guess, I'd say your APPS. phox |
what should I do?
Look in the "Tech Facts" above. The is one procedure for "re-setting" the APPS and one of doing the "Recal".
cool i will do that and then we will see what happens
ok reset the APPS but it is still showing the P0123 code but the others are gone
Originally Posted by TexMexCowboy
(Post 1582850)
kool ill try that here pretty soon.
