Truck died on freeway...
Old Aug 24, 2006 | 07:01 PM
lezmark7's Avatar
70 mph on freeway and it just died - wont restart. Disconnected batteries (on freeway) twice to reset computer - no good. Did the click the key a few times and get a P1693 code. Help! Is this VP44 death? Had the truck towed home, now I need to figure out what to do next...
Old Aug 24, 2006 | 07:20 PM
lezmark7's Avatar
Forgot to mention - great fuel pressure, based on gauge tapped into base of IP
Old Aug 24, 2006 | 07:24 PM
Viperdew's Avatar
P1693 is nothing but a code telling you that there is a code. Was there another code along with it?
Old Aug 24, 2006 | 07:30 PM
lezmark7's Avatar
That was all there was - the code showed and then the word done... any ideas?
Old Aug 24, 2006 | 07:47 PM
Rauschbo's Avatar
Could be the VP - it often won't give a code when it dies; Ck for fuel at the injectors!
Old Aug 24, 2006 | 08:57 PM
blackdiesel's Avatar
Registered
did it say pcu done then ecu done? it should check both. and i think 0216 comes up in the ecu.
Old Aug 24, 2006 | 08:59 PM
Geico266's Avatar
Send a PM to Shovelhead. He had the same thing happen to him. No codes, dead VP-44.
Old Aug 24, 2006 | 09:03 PM
RCW's Avatar
RCW
P0216 is the code sent when the system detects failure of the control board in the VP44 itself. That pretty much cinches it as a failed VP44.
Old Aug 24, 2006 | 09:18 PM
lezmark7's Avatar
Well, I just cracked a fuel line - dry as a bone. Nada, nothing. Guess its HRVP time. Anyone on how these hold up compared to the regular?
Old Aug 24, 2006 | 09:26 PM
Registered
the new pumps are supposed to be better. hold up to heat and vibration better than the stockers. the hrvp may give you a lope at idle, but a noticable increase in power. give doug at pdw a call
Old Aug 25, 2006 | 05:42 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Try to avoid a remanufactured pump that is painted black.
Usually purchased at a "Chain" type auto parts stores and sometimes at the dealers.
They're reportedly rebuilt overseas and are more prone to early failures.
bigNtall
Mar 16, 2008 08:40 PM
HOV
Feb 5, 2008 09:58 PM
Rampage1967
Jan 31, 2008 05:00 PM
Rampage1967
Jan 20, 2008 05:37 PM
