Truck died
Old Aug 21, 2003 | 06:45 AM
Hired Gun's Avatar
Truck died
Last night I was leaving a parking lot. Well I was going through the gears
and accelerating really hard. Like I normally do. Well the truck didnt miss, or anything, it just died. I
coasted to a stop and tried to restart it. Nothing just cranked until battery went low.
It was late so I didnt try to add fuel and crack some lines yet. It was on about an 1/8
of a tank of fuel.
Could it be empty?
Help.
Old Aug 21, 2003 | 07:28 AM
Mexstan's Avatar
Re:Truck died
If it were my truck I would view the fuel gauge with great suspicion. Guilty until proven innocent sort of thing. Try putting in about 10 gallons or more, bleed the system and see what happens. If when bleeding the system a lot of air comes out and the truck runs normally after that, you can fairly safely assume that the sender unit has gone south. If it still will not run, well then maybe the pump died. I always fill my tank to the top at each fill and zero the trip indicator. This way I have a dual fuel indicator, plus it gives me a rough idea if something suddenly goes wrong with fuel consumption. Been doing this for years on all my vehicles and now tend to go by mileage rather the fuel gauge before filling up.
Old Aug 21, 2003 | 09:36 AM
barracuda's Avatar
Re:Truck died
mine did that exact same thing once and i was ordering a VP-44...just shut off and cranked freely, happened under a bombing run like you were doing....not trying to scare you but wanted to reply w/ a similar incident...Hope u just ran out of fuel, good luck.. :
Old Aug 21, 2003 | 12:45 PM
Hired Gun's Avatar
Re:Truck died
Well a friend of mine had the same thing happen a few weeks ago, and his sending unit was bad.
I am hopeing mine is the same since it is at the same mileage as his was when he had that happen.
I have a new transfer pump, and when it died the pressures were great. It was sitting on 12psi
at WOT.
I cant wait to go home and work to see if she will run. I hate being without my truck. Its like a family member is sick
or something.
Old Aug 21, 2003 | 01:02 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Re:Truck died
The fuel sending units in the tank, are notoriously bad in these vehicles. I hope that it turns out to be nothing but that for you as well.
Good luck!
Old Aug 22, 2003 | 12:33 AM
AlpineRAM's Avatar
Re:Truck died
[quote author=Hired Gun link=board=13;threadid=18676;start=0#msg175281 date=1061487942]
at WOT.
[/quote]
Sorry to say so, but I think you aren't lucky.... having fuel pressure indicates that it wasn't an empty tank.
I hope that I am wrong..
AlpineRAM
Old Aug 22, 2003 | 12:48 AM
geer's Avatar
Re:Truck died
I was traveling down the road with the cruise on and lost my injection pump. It was on my 99 2500.
Old Aug 22, 2003 | 07:08 AM
Hired Gun's Avatar
Re:Truck died
Well I cracked some lines and fired it up last night. It will Idle smooth, but when trying to
give it throttle, it runs very rough. I also noticed the check engine light, and ABS
along with brake light stays on.
Old Aug 22, 2003 | 07:49 AM
barracuda's Avatar
Re:Truck died
i tried to crack my lines and so forth and mine wouldnt do anything when my VP went...hopefully its something else then...i wish i could help more, good luck ???
Old Aug 25, 2003 | 08:29 AM
Hired Gun's Avatar
Re:Truck died
Well thanks to some fellow DTR members, and some none menbers, I found the problem.
MAP sensor.
Anybody have a cummins price and part number for the 99?
Old Aug 25, 2003 | 09:44 AM
DODGE4X4's Avatar
Re:Truck died
I think you are out of Diesel
Old Aug 25, 2003 | 10:02 AM
Hired Gun's Avatar
Re:Truck died
I wish it was that. It is full and will run at idle.
I ran a scanner on it yesterday and it came up a map sensor failure.
Old Aug 25, 2003 | 10:54 AM
Farmall's Avatar
Re:Truck died
Get a hold of Darrell B. Either here or at your all's site. I know he has replaced 2.
Bill
Old Aug 25, 2003 | 12:21 PM
Hired Gun's Avatar
Re:Truck died
Thanks Farmall.
I remember him saying he had done that a couple times. Thanks!
rip 112
13
Sep 9, 2013 10:27 PM
Tommy93w350
20
Nov 1, 2005 11:07 PM
DRD
15
Apr 6, 2003 07:59 PM
bdog
Mar 5, 2003 12:37 AM
Desert Diesel
Dec 6, 2002 03:54 AM
