Truck broke down after VP-44 replacement!
Old Apr 17, 2009 | 09:33 PM
Boilermaker08's Avatar
I replaced my vp44 and all seemed to be well. Truck fired right up, had good power. I did have a CEL on at first but everything seemed ok, I figured it might have something to do with my edge electronics. I decided to take it to autozone to have them check the code anyways, the truck started stumbling but still ran pretty good. It eventually kept stumbling and quit running altogether. I bled the lines and tried restarting it, with some success and it would run for about 30 seconds before stalling again.
Now the truck won't even fire at all. What are the chances that the fuel filter could cause this, I do have an Airdog 100 Fuel system and no part number for the filters. I plan on replacing them as soon as possible but right now my truck is broken in a empty parking lot in West Lafayette, IN.
Help please!
Thanks,
Greg
Old Apr 17, 2009 | 10:56 PM
HotRodTodd's Avatar
Never change your pump without changing the filters and flushing the lines first.
Do you have a fuel pressure gauge? Did you verify you have the proper fuel pressure before starting your truck?
I don't know where you got your pump from, but we get ours from Bosch and they will not warranty their pumps unless the fuel filter and lift pump was replaced at the time of installation of the injector pump or an idiot light or gauge must be installed if using an existing lift pump.
Old Apr 18, 2009 | 09:49 AM
Thanks, I bought my pump from Scheid's in Lafayette, I am going to go back and work on it again today, hopefully I have some luck.
Old Apr 18, 2009 | 12:08 PM
Erik@LCD's Avatar
You gotta do the lift pump and or filters with a VP. ALthough unlikely with the Airdog, a lack of supply pressure may have killed the VP to begin with. Hopefully you didn't kill the new one also. Make sure you have a fuel pressure gauge or at least a low pressure light installed ASAP. Good luck!
Old Apr 18, 2009 | 02:34 PM
RacerRon's Avatar
I'd unplug the edge data port connector, clear the codes, and see if it'll run.
What codes did you get on the scan ?
Old Apr 18, 2009 | 02:42 PM
HotRodTodd's Avatar
He obviously does not have a scan tool.
He said he was taking the truck to Auto Zone to have them read the codes when it quit running.
Old Apr 18, 2009 | 03:11 PM
I changed the filters, added a gallon of fuel ( I was low, my fuel gauge is off) and charged the battery because it was low also. I bled the lines and cranked and eventually it started up!
Im not sure if it was a filter issue or if I ran out of fuel...but when I went to fill it up it took a near 35 gallons. The CEL is not on anymore and all seems to be good.
I would like to thank everybody for their help, I will hook up a low fuel pressure gauge as soon as possible.
Old Apr 19, 2009 | 10:26 AM
rattlerbob5.9's Avatar
You were out of fuel with little to no pressure and full of air as i was reading from your first post i was thinking bad gauge and out of fuel .
Now you have seen first hand the need for a real fuel pressure gauge and not just a light it would have shown you the problem before it died.
Hopefully you did not hurt the new vp. Also fill up when you get down to a 1/4 tank the cooler the fuel threw the pump the better when you run them low like that the fuel gets very hot.
Old Apr 19, 2009 | 02:23 PM
johnh's Avatar
you really need to fix your fuel gauge, or keep it full. when i ran out of fuel my gauge read just over 1/4....... it didn't hurt the VP44, probably because i had a pretty strong mixture of two stroke oil in
doomgaze
Nov 11, 2009 08:53 PM
cluckmaster
Dec 31, 2007 01:48 PM
dspencer0590
Nov 16, 2007 07:50 PM
deviousracing
Sep 12, 2004 12:15 PM
Madoco
15
Apr 27, 2004 02:33 PM
