Transmission - Is is Gone?!?!?
Old Jul 12, 2008 | 11:12 PM
rbox's Avatar
Transmission - Is is Gone?!?!? (48re)
Got off the interstate tonight and went to accelerate and all the sudden tranny doesn't want to upshift. It takes forever to upshift. I'm not sure if it is even going into 4th or not. I could barely get it out of 1st and had to nurse it home. It seems like it pulls good though, I don't think it's slipping. Reverse is good.
Could it be a loose vacuum hose? I was tightening some fuel line clamps today on the engine. Could I have knocked a line loose or could it be a more grimm diagnosis?
Old Jul 13, 2008 | 08:39 AM
mikmaze's Avatar
ya sure you had the selector in D, I will catch my truck acting funny if I don't quite get it all the way in, truck acts real funny........ check that, check your fluid for quantitiy and is it burnt. take a deep breatha nd take it back out see if it is still doing it makin sure ya have it in D
Old Jul 13, 2008 | 10:50 AM
j-fox's Avatar
Gets the codes read.
Old Jul 13, 2008 | 11:50 AM
rbox's Avatar
Yep I toggled the selecter between 1-2-D-N several times to make sure that wasn't the issue. I also drove it several miles like that last night (had to to get home). Stopped at wal mart on the way so it was shut off for 30min or so and it still did it. I turned it off and back on a few more times too. No change.
I went out and checked the codes last night and no codes. goes to -done- immediately.
Like I say it doesn't seem like it slips when its in gear, it pulls good. It just doesn't want to upshift. GOV Solenoid or speed sensor maybe?
Old Jul 13, 2008 | 11:53 AM
Hercules's Avatar
Hopefully it's as simple as mikmaze suggested with the selector not being fully engaged in "D". For me, though, I needed to have the trans rebuilt in my previous truck (97 Ram w/360 & auto trans) when it did something similar. If I remember correctly, I only had 1st and 2nd. Or was it only 1st that I had left? Anyways, a planetary gear came apart causing my problems. It took a rebuild to fix it. I ended up rebuilding that trans 3 times during the time I owned that truck then traded it in on the Ram I have now when it started acting up a 4th time.
Old Jul 13, 2008 | 05:14 PM
dozer12216's Avatar
How long since tranny serviced. See advice to 47 RE help.
Old Jul 13, 2008 | 10:04 PM
oldblues's Avatar
hi
fluid level in NEUTRAL engine running !
bad tps was my problem not the trans !
Old Jul 13, 2008 | 11:58 PM
rbox's Avatar
Originally Posted by oldblues
hi
Checked in neutral hot, full but bubbly.
Old Jul 14, 2008 | 06:45 PM
Hercules's Avatar
What color was the trans fluid when you checked it?
Old Jul 15, 2008 | 12:05 AM
rbox's Avatar
Red, like normal.
Old Jul 15, 2008 | 07:12 AM
1-2-3's Avatar
Just a plain ole guy
Could be as simle as the speed sensor. Mine acted funny and it was a $35 sensor. You can change it yourself. I beleive it's towards the rear on the drivers side. Has electric plug going to it. Be worth a try.
Old Jul 15, 2008 | 09:18 PM
J BODY's Avatar
WoW! haven't figured it out yet???
Old Jul 15, 2008 | 11:07 PM
rbox's Avatar
It's going to the dealer Thursday so they can diagnose it.
Thanks for the replies and I will post back my results.
Old Jul 17, 2008 | 01:24 PM
DVANN's Avatar
My Dodge gasser was doing the same thing and it was the GOV sensor, but the computer was throwing a code for high/low GOV signal as well as acting weird.
Old Jul 17, 2008 | 05:45 PM
ado2b1's Avatar
I know I don't have the same truck, but mine did the same thing (pulling strong, did NOT want to shift). I replaced the governor pressure sensor and solenoid and the problems were fixed.
You might look into these two parts. But definately get a second opinion OTHER than the dealer. I don't know about the ones where you live, but they like to rip folks off every which way from Sunday here.
http://www.transmissionpartsusa.com/...-00053397a.htm
http://www.transmissionpartsusa.com/...-000053396.htm
arroyojim
48
Sep 9, 2016 09:43 AM
cbrahs
Nov 1, 2011 11:00 AM
TAMU
May 27, 2009 06:34 PM
TAMU
Apr 27, 2009 11:26 AM
3500Dooly
23
Jun 8, 2006 10:21 PM
