its GONE ALL GONE
Old Jun 1, 2006 | 02:25 PM
3500Dooly's Avatar
Angry its GONE ALL GONE
this isnt quite drivetrain....so i hope this is ok?
our truck just lost its clutch!!!!! it has 78k on it and this kinnda pissis us OFF! the only pulling it has done was the man before us pulled 5th wheel campers from AZ to ME untill the truck hit 13k then he bought a 2x2 so he could pull the campers from the south better and had a 12 speed put in for better MPG.
so now at 78k the clutch just blew, the stinkin thing hasnt even been pulling for 3 months now and the only thing we pull on a reg bases is a 14ft job trailer!!!
we had the truck pulled ($400 ) to the dealler to see if it was under warranty--it isnt cause its not drivetrain---good enough but they want over $1300 bucks to do it!!
this is what they said to my father "do you pull with this truck?" he said "ya a small trailer."......"oh thats prolly why the clutch went."
so i guess what this means is if you want to pull a 14ft tool chest you gotta buy a freakin Peterbuilt!!!!!!???????
Old Jun 1, 2006 | 02:46 PM
xmr's Avatar
xmr
Man that is really sad. I hope you can find some one other than the dealer to install a clutch. I would think that would be cheaper than $1300.
Old Jun 1, 2006 | 02:55 PM
kantdrive55's Avatar
DTR Advertiser
If you are going to have to replace the clutch I might be tempted into looking into a better clutch. We use the South Bend clutches here with great results. No difference in feel really from the stock one compared to the performance.
Old Jun 1, 2006 | 02:56 PM
RustyJC's Avatar
You don't give any specifics about your truck, but if you're gonna spend $1300, you can buy a SBC (South Bend Clutch) Con OFE and pay to have it installed - probably with money left over.
Rusty
Old Jun 1, 2006 | 03:17 PM
BigBlue's Avatar
Since when was the clutch not part of the drivetrain?
Old Jun 1, 2006 | 03:44 PM
RustyJC's Avatar
A clutch disc is normally considered a wear item like brake pads. IIRC, after 12 months or 12K miles, you're pretty much outta luck with clutch replacements under warranty.
Rusty
Old Jun 1, 2006 | 03:58 PM
nitrousn's Avatar
Rusty
Exactly. Thats the way its always has been. It dont matter if its a fart cart omni or a big 3500 dually clutches are a consumable item.
Old Jun 1, 2006 | 04:02 PM
BigBlue's Avatar
Oh I'm not arguing that point. That's understandable. But since when was it not considered part of the drivetrain. I'd be a little suspicious if my dealer told me that.
Old Jun 1, 2006 | 04:06 PM
RustyJC's Avatar
Oh, OK, I see your point. Yeah, there's a big difference between "Sir, your clutch is not covered by the drivetrain warranty" and "Sir, your clutch is not part of your drivetrain".
Rusty
Old Jun 1, 2006 | 05:11 PM
nitrousn's Avatar
As i recall it is spelled right out in the customers warranty booklet.
Old Jun 1, 2006 | 06:16 PM
Yukon Dodge's Avatar
It would be sad to spend that much money at a dealer, and still only have a stock clutch!
Old Jun 1, 2006 | 06:53 PM
bsmurf12's Avatar
Sounds like the guy before was riding the clutch while loaded...In no way should the clutch burn out at 78k.
Old Jun 1, 2006 | 07:47 PM
BCB's Avatar
BCB
on my 97 the clutch just fell apart at 40,000 with my dad driving all of that. granted he was pulling a pretty good load but in no way did he ride the clutch excessivly (sp). I had a buddy with a 98 24V in about the same situation you are in. From my understanding the stock clutches are crap.
Old Jun 1, 2006 | 10:13 PM
My personal beef with the stock clutch assembly is that the cheesy 3/4" diameter pilot bearing seldom lasts the life of the clutch. From what I read here, it seems that most of these assemblys get replaced due to failure of the disk or pressure plate; I don't think I've ever heard of one slipping to the point of failure. I pulled my clutch out after it had been in there for two years, and the disk still had the imprint on it from the factory stamp, and most of these miles are loaded as per my signature. So yes, it most likely was being ridden...be interesting to see what it looks like coming out of there.
Old Jun 1, 2006 | 11:30 PM
3500Dooly's Avatar
you would think so but the guy was even more **** about the truck then I are. and also the clutch wasnt even broken in when we bought it.
and me and my father can both drive stick well...hes been drivin a manual for most of his life. i think its just a bad clutch.
our reg. mechanic will tow from the dealer and put in a new clutch for 1060.
any idea what clutch you have liked the best?? thanks
