Transmission fluid capacity
Old Oct 5, 2003 | 03:13 PM
orcaburger's Avatar
Anybody know what the fluid capacity of a dodge 47r auto trans. is? Seems to be a secret. I caan't find it anywhere. Guess I'll have to pay up for a shop manual.
Old Oct 5, 2003 | 05:22 PM
amartinson's Avatar
Re:Transmission fluid capacity
On Dodgeram.org they state that the amount needed for a fluid change (assuming you only drop the pan and refill) is 6.5 quarts. They do not mention total capacity.
Old Oct 5, 2003 | 08:40 PM
Den052's Avatar
The actual capacity is about 11-12 quarts with a dry converter. I have overhauled many Dodge transmissions but no diesels. This transmission they stick behind the Cummins is a big brother of the old Chrysler torqueflite 727 and 904 transmissions. They were 3 speed units and are nearly identical inside the main housing and the transmissions we now have. They added an overdrive unit on the back, which makes the current transmission a 4 speed. Also they have beefed them up to stand up behind the Cummins. But the fluid capacity remains pretty much the same.
LockedandLoaded
Jan 17, 2008 02:51 PM
steerjock
Dec 4, 2006 07:20 PM
johnr9q
Apr 8, 2006 12:18 PM
ouchman
Feb 25, 2006 11:22 AM
BuckBoardDriver
Jul 3, 2003 07:30 AM
