47RE Transmission Fluid Capacity
Old Jun 14, 2003 | 03:00 PM
BuckBoardDriver's Avatar
Getting ready to change the tranny fluid for the first time. For the life of me, I cannot find the capacity. From reading threads, I get the impression it is anywhere from 10 to 17 quarts.<br><br>I am planning on doing a complete change as I intend on changing to Amsoil. Anyone have a good figure so I can order the correct amount of fluid?
Old Jun 14, 2003 | 11:19 PM
turbodiesel_ram's Avatar
Re:47RE Transmission Fluid Capacity
I never changed mine, but from what I've seen it is somewhere between 5 to 6 1/2 quarts.
Old Jun 14, 2003 | 11:30 PM
Correction to my last post...17 quarts if dry, 5 to 6 1/2 if just changing the fluid.
Old Jun 16, 2003 | 08:47 AM
NWDave's Avatar
Just did mine a couple weeks ago. Note, Double Deep tranny pan. Took 16 qts. Drained TC, VB and pan of course. <br><br>~Dave
Old Jun 16, 2003 | 05:22 PM
Thanks. I am going to the Mag Hytec deep pan. Sounds like I will need 17qts for sure.
Old Jun 17, 2003 | 12:55 PM
MCummings's Avatar
Has anybody tried the &quot;Trick* of disconnecting the &quot;Hot&quot; line going to the transmission cooler, connecting a hose to it, and running it into a bucket, and then turning the truck on, and cycling the truck through the gears until bubbles start coming out?<br><br>I've heard of this being done on other trannies, but haven't heard it being done on 47RH/47RE/48RE trans.<br><br>Thanks,<br>Merrick Cummings Jr
Old Jun 18, 2003 | 06:49 AM
Everything I have read says to change the tranny oil when it is hot. Why would that be. My 'baby' is my third vehicle and sits for days at a time. When I fire her up, it always takes a bit for the fluid to get pumped back into the TC and I suppose the VB.<br><br>Seems to me it would be best to drain it after a few days since all of the fluid has naturally drained out of those parts. <br><br>Would it be possible to open her up and just let it sit for a couple of days to drain the cooler instead of loosening a line and pumping the fluid out?
Old Jun 19, 2003 | 09:32 PM
DODGE4X4's Avatar
Just had mine totally Flushed, it took 16 quarts. But, if you are just dropping the pan it should be about 6 to 7 quarts. Hope this helps.
Old Jul 3, 2003 | 07:30 AM
WA4SLC's Avatar
I removed the line that goes in the rear drivers side, which is the return from the cooler. I put a peice of clear tubing on the line and twisted a peice of wire over it to keep it from comming off. I had mesured the fluid that came out when I droped the pan and put that much in to start. I ran the engine with it in neutral for about 60 seconds at a time. I measured the amount of fluid that was pumped out and added that amount every time. When I was satisfied all of the old stuff was out I put the line back on and brought the fluid level up to the full mark.
Bill
LockedandLoaded
Jan 17, 2008 02:51 PM
steerjock
Dec 4, 2006 07:20 PM
johnr9q
Apr 8, 2006 12:18 PM
ouchman
Feb 25, 2006 11:22 AM
orcaburger
Oct 5, 2003 08:40 PM
