Fluid Capacity Of My Transmission
Old Apr 8, 2006 | 10:07 AM
johnr9q's Avatar
I changed my trans filter and fluid according to the info in my 1999 Mopar Service Manuel. (I just lowered the pan and then let the trans drain) The manuel said I should only get 4 quarts out but I got 9 quarts. Then on the refill procedure, the manuel said I should only put 3 pints in it initially, then start the rig and add to the min mark on the dipstick then drive and get it warm and add to the maximum mark. After I put the 3 pints in and started it, I added another 2 gallons which I would expect based on how much I drained out but why does the manuel say a filter and fluid change should only net 4 quarts and on first fill add only 3 pints? My friend told me the best Transmission fluid to use is ATF+4 even though the manuel recommends ATF3. Any opinions?
Old Apr 8, 2006 | 11:29 AM
Olratlr's Avatar
Maybe you have a double dish pan on it. If your manual says use ATF+3
use that it's a lot cheaper than ATF+4 by any chance did you drain the valve
body are torque converter?
Old Apr 8, 2006 | 12:18 PM
johnr9q's Avatar
Thanks for the input olratlr. How would I know if I had a "double Dish pan"? As far as I know I didn't drain the torque convertor or the valve area. I just dropped the pan and let whatever was in the trans and pan drain out. I was using fully synthetic trans fluid (Amsoil) to get longer service over the ATF+3 but my friend, who is a cummins pro, said I would also get longer service if I switched to ATF+4
LockedandLoaded
Jan 17, 2008 02:51 PM
steerjock
Dec 4, 2006 07:20 PM
ouchman
Feb 25, 2006 11:22 AM
orcaburger
Oct 5, 2003 08:40 PM
BuckBoardDriver
Jul 3, 2003 07:30 AM
