transmission
Old Jul 5, 2004 | 01:59 PM
racermatt2606's Avatar
transmission
my transmission keeps going from 3rd to 4th. I was gogin 85 down the interstate the other day and it kicks back from 4th to 3rd. at 3rd its goverend to 72MPH. what makes it do this.
Old Jul 5, 2004 | 02:38 PM
phox_mulder's Avatar
Assuming your talking about an automatic transmission?
(if not, you gotta stop downshifting there )
What year vehicle?
What rear end gearing, what size tires?
It is actually shifting out of overdrive.
This could be due to any number of reasons, depending on year of vehicle.
phox
Old Jul 5, 2004 | 02:56 PM
Its a 92 automatic. Dana 60 rear end. Normal size tires. everythign shuold be ok. the guy we bought it from said spray WD40 on this black peice on the pump but that didnot fix it.
Old Jul 5, 2004 | 03:06 PM
92 is too old for me.
Plastic piece is probably the TPS, most likely it has outlived itself.
Hopefully others with more experience with the old automatics will come back from the holiday and chime in.
phox
Old Jul 5, 2004 | 09:23 PM
Steve Roseman's Avatar
I don't own a first gen, but from what I've read it sounds like the TPS. That black piece on the pump is the TPS. With the truck off, tap on it with a hammer while working the throttle back and forth, this might get a few more miles out of it.
Old Jul 6, 2004 | 10:15 AM
BIG&BAD's Avatar
heres some reading on how to clean the tps
saves you some 250 bucks
https://www.dieseltruckresource.com/...&highlight=TPS
Dauntless
15
Aug 30, 2016 08:37 PM
dsl-nut
Mar 22, 2003 12:12 PM
quantrill88
Mar 19, 2003 05:04 PM
harleydog
Mar 13, 2003 07:34 PM
jonesr2
Oct 12, 2002 04:49 PM
