Tranny wont shift / code P 1757
Old Jun 24, 2007 | 03:39 PM
shannong's Avatar
Just took the truck out on the road and it won't shift out of first. Climbed back up the mountainous drive (yes I am in OK) IN 4WD and noticed no slippage. Got a code of P 1757. Could anyone please let me know what I am facing? Any help would be greatly appreciated.
Old Jun 24, 2007 | 11:39 PM
oldblues's Avatar
hi
something to do with govenor psi higher than 3 lbs at idel in gear sitting still ?
Old Jun 25, 2007 | 04:19 AM
shannong's Avatar
Thanks, at least that tells me where to start. I've got about 140,000 miles on it and do very little towing. Could some of you give your opinion whether to do the repair or a complete rebuild? Thanks again.
Old Jun 25, 2007 | 07:23 AM
vzdude's Avatar
DTR's 'Go to Guy'
Really need to get a scanner and do some diagnostics first. It could be as simple as the governor pressure transducer and solenoid need replaced. Those only cost about 175 bucks and a couple of hours ( if you are slow ). Or it could be worse. Without spending some time or money to find out, you could waste money on a trans rebuild and may not need it.
Old Jun 25, 2007 | 09:51 AM
53 willys's Avatar
yep he is very right....the gov press sensor and solenoid seem to go on these pretty often but you need a scanner(a really good one)to read what the trans is doing...
Old Jun 25, 2007 | 11:10 AM
Rollin' Smoke's Avatar
my buddy had the same code on his truck the other day but he was had been stalling the truck up a few times. cleared the code and nothing since
Old Jun 25, 2007 | 11:13 AM
shannong's Avatar
Took it out again and was able to get it to shift by letting off of the throtle while going downhill but once it got going uphill it would downshift HARD! I realy dont want to downshift to 1st while going hiway speeds so I,m having it towed into a mechanic. Thanks to everyone for there help.
rustydeeretech
Jun 16, 2010 09:41 AM
Timberman
Oct 14, 2007 05:24 PM
moparman13045
Jan 16, 2007 06:10 PM
noworries
Nov 7, 2006 10:15 PM
04 SO CA
Apr 21, 2004 07:35 PM
