Tranny Band adjust
Old Jun 6, 2004 | 07:13 PM
ramman21921's Avatar
Question Tranny Band adjust
I have a shop manual that tells me for auto band adjust front band torque to 72 in-lbs and back off 1-7/8 turns. Back band torque to 72 in-lbs and back off 3 turns. these specs are for the 47re and the latest year I have is the 98 model. Are the specs for the 2001 model the same? I would appreciate any input or experience from anyone that knows.
Old Jun 6, 2004 | 08:04 PM
jman's Avatar
hope this helps
jman
2000-2001
Front Band
42RE - Tighten to 72 in-lb, back off 3 turns
44RE - Tighten to 72 in-lb, back off 1 7/8 turns
46RE - Tighten to 72 in-lb, back off 2 7/8 turns
47RE - Tighten to 72 in-lb, back off 1 7/8 turns
rear band
42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
47RE - tighten band adj. screw to 72 inch pounds, back off 3 turn
Old Jun 7, 2004 | 07:20 AM
infidel's Avatar
Most diesel tranny gurus recommend not adjusting your bands routinely but rather only if you have slippage in 1st or reverse. Most times routine adjustment just causes faster tranny wear.
Old Jun 7, 2004 | 09:31 AM
thumper 549's Avatar
if you have a slipy trany adj. the bands will not help........unless they are a mile out then you will or could get a dragged out shift...the band stops the sungear drum from turning (like a parking brake) works or not,,not of a lot of in between.
Old Jun 7, 2004 | 04:56 PM
My trans is not slipping I was going by the repair manual and it suggested to adjust bands every time a trans service was done.
Old Jun 7, 2004 | 06:58 PM
then your on the right course.....lots of after market (Tow and Go?) peo will recomend a slightly diff adj.- but if it close it will work just fine.
04ctd
Aug 29, 2008 03:16 PM
92cummisw350le
Jan 6, 2008 07:21 PM
BobQ
Mar 28, 2006 10:27 AM
betsycam
Sep 26, 2004 03:44 AM
