track bar replacement
Old Nov 20, 2010 | 07:19 PM
AlanF's Avatar
Just put in another starter, may as well replace the track bar while at it. Can't get the frame side ball joint to sit in place. I am doing this solo, am having hard time gettting the ball joint to fit in place. I think it would be easy with someone turning the wheel while I steer the ball joint in place. Any suggestions..... am getting cold and ****** off here! Please and thankyou.
Alan
Old Nov 20, 2010 | 08:55 PM
OldDodgeOwner's Avatar
Hook a ratchet strap from the frame to the axle. You can suck it up into position pretty easy.
Old Nov 20, 2010 | 09:33 PM
AlanF's Avatar
track bar
Thanks for the help regarding strap. I finally called my girlfriend and 2 minutes later I had it home. Grrr. Haven't had a good go on the highway yet where I had the worst of the wandering happening. Hopefully handles better, certainly starts better.
Alan
Old Nov 20, 2010 | 10:24 PM
torquefan's Avatar
As mentioned, a ratchet strap will work. I've often used a come-along the same way. Last one I did, I just got out from under the truck and turned the steering wheel a bit one way, and it helped align things enough for me to do it alone.
CTD2001
Aug 22, 2009 10:03 PM
Dinner
May 29, 2007 02:02 PM
kwillis-a
Jan 25, 2007 09:10 PM
mbmrang
Sep 13, 2005 10:01 PM
McGyver
Aug 13, 2003 06:02 PM
